Ex Member Posted December 3, 2019 Share Posted December 3, 2019 The two end horns move. Try the gasket on the head not the manifold. Quote Link to comment Share on other sites More sharing options...
marieholm Posted December 16, 2019 Author Share Posted December 16, 2019 All, its in! The engine is running again. But I think I hear a noise which was not there before. It’s sounds like a rattle. what do you make of iT? I did not drive it yet so the engine is still cols as i filmed iT. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 16, 2019 Share Posted December 16, 2019 Sounds like a manifold leak.....? I guess you don't know if it makes boost yet.... Quote Link to comment Share on other sites More sharing options...
marieholm Posted December 16, 2019 Author Share Posted December 16, 2019 Does iT? Ill check the bolts. I was afraid iT was the nee turbo...... no idea about the boost yet. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 16, 2019 Share Posted December 16, 2019 Turbo's don't tend to rattle, what else have you had apart? Quote Link to comment Share on other sites More sharing options...
monkie Posted December 16, 2019 Share Posted December 16, 2019 I think Bowie is right. I can also hear a hiss of air or exhaust escaping. What were the mating surfaces of the head and manifolds like? Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 17, 2019 Share Posted December 17, 2019 That is a loud hiss of a gas leak. It’d be worth spraying with soapy water while cold to pin it down. You did refit the big o-ring between the cartridge and the compressor housing, didn’t you? Quote Link to comment Share on other sites More sharing options...
marieholm Posted December 17, 2019 Author Share Posted December 17, 2019 Thanks for all the tips. it seems like the manifold/exhaust is leeking. I can feel the air flow by it. Can you "overtighten" the clamp? is their a risk of breaking the manifold? Quote Link to comment Share on other sites More sharing options...
western Posted December 17, 2019 Share Posted December 17, 2019 If you mean the downpipe to manifold you won't break the manifiold, by tightening the clamp, more likely to strip the clamp bolt thread first, did you apply some exhaust sealing paste to the downpipe before fitting it to the manifold section. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 18, 2019 Share Posted December 18, 2019 9 hours ago, marieholm said: Thanks for all the tips. it seems like the manifold/exhaust is leeking. I can feel the air flow by it. Can you "overtighten" the clamp? is their a risk of breaking the manifold? Do you mean the manifold to head joint, manifold to turbo flange, or turbine casing joint (the seven studs and oval shape in the elbow), or the elbow to down pipe? If you mean manifold to head, then the risk there is shearing the studs. If you removed the manifold earlier to separate the turbo on a bench, did you replace the gasket on reassembly? Quote Link to comment Share on other sites More sharing options...
