trod Posted October 23, 2020 Share Posted October 23, 2020 Hi,are the hole pitches the same on a series 2 and a series 3. Thanks Trod Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted October 23, 2020 Share Posted October 23, 2020 Yes but the S2 hinges are better if you look after them and change the balls before they wear out. They are only very cheap. Peter Quote Link to comment Share on other sites More sharing options...
trod Posted October 23, 2020 Author Share Posted October 23, 2020 great! so now im looking for 2 l/h lower hinges,if any one has them or good place to buy them (part number 346342)i will be fitting them on a lightwieght door,so the upper and the lower need to be the same deth Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted October 23, 2020 Share Posted October 23, 2020 Dont mix S2 and S3 hinges on the same door. The pivots are not in the same plane. Peter 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 23, 2020 Share Posted October 23, 2020 The S3/Defender type are angled pivots too ... The rear door hinges might make more suitable conversion hinges cheers Steve b Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 24, 2020 Share Posted October 24, 2020 Lightweights use completely different hinges to the standard bodied models. You’ll need the right parts for the job. Dunsfold Land Rover and PA Blanchard are your best bet for decent (genuine) new hinges. Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted October 24, 2020 Share Posted October 24, 2020 (edited) The issue is door-mirrors with S2 hinges, or not. Unless you run wing-mirrors, you're in for some messing. S3 part MRC4583 can be made to fit, as can coiler type mirrors. But it takes some searching, adaptors and/or the original S2 part MRC56. MRC56 is made of unobtainium. You'll be wanting brackets 347704 347705 too. And don't even mention the price of the milly version of S2 hinges (with integral mirror-mount). last I looked £300 a set! Edited October 24, 2020 by Landrover17H Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 25, 2020 Share Posted October 25, 2020 14 hours ago, Landrover17H said: The issue is door-mirrors with S2 hinges, or not. .... And don't even mention the price of the milly version of S2 hinges (with integral mirror-mount). last I looked £300 a set! 'Robin' on the Series 2 Club forum will modify your S2 hinges to include the mirror-mount; the supplier can specify the diameter of the hole, to suit their mirrors. He also sells via Ebay. However, I share the view that true Lightweigt hinges are different to S2 hinges, so my comments above may not be applicable. Regards. Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted October 25, 2020 Share Posted October 25, 2020 Been down this road, this may help: https://forums.lr4x4.com/topic/107805-s2-hinge-door-mirrors-for-the-classic-look/ Quote Link to comment Share on other sites More sharing options...
trod Posted October 26, 2020 Author Share Posted October 26, 2020 I am now looking for 2 lower L/H series2 door hinges can any one help?.PS thanks for the feed back Quote Link to comment Share on other sites More sharing options...
