Mean Green Posted October 26, 2020 Share Posted October 26, 2020 Has anyone successfully replumbed the fuel tank on a 200tdi 90 to fit newer style wings with the fuel filler at the rear rather than at the drivers door? Where do you run the filler pipes? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted October 26, 2020 Share Posted October 26, 2020 Rear mounted fillers are for rear mounted tanks. Short of running a pipe between the wheel & spring, it's not going to work. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 26, 2020 Share Posted October 26, 2020 I’ve got the opposite problem and was going to try and solve it by removing the old wing skin and buying a Td5 one, which will put my filler in the right place for a rear tank. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 26, 2020 Share Posted October 26, 2020 Why not cut the front filler neck out of an old 90 tub or skin, clean it up and rivet into place on the new skin. It wouldn't look out of place. I considered this when thinking about adding a second tank under the seat. In the end I decided a second battery box was more useful so it never came to fruition. Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 26, 2020 Share Posted October 26, 2020 I’ve seen it done with a welded pipe following the inside of the wheelarch. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted October 28, 2020 Share Posted October 28, 2020 I have it the opposite way round, with the filler in the 300tdi position, and a Puma/TD5 rear tank. The filler pipe runs back to the tank. It is one of those stopgaps that has persisted; the problem is if you park on a steep slope downwards (or in the OP's case upwards) with a fullish tank the fuel goes up the filler pipe and leaks out of the cap. YRM do the cutouts for a filler, both new and old. Quote Link to comment Share on other sites More sharing options...
