Defender Floor Plates
13 hours ago, reb78 said:
Would it be easier and cheaper to just cut some from some ali sheet Ross? They are just flat panels.
I don't think that Ross has suitable workshop facilities or the equipment to do simple cuts of sheet aluminium. Grabs coat ...
  • Haha 1
4 hours ago, Dr Strangeglove said:
I believe thicker material stops more noise, but that also depends on density so I don't know how that will go on changing from steel to aluminium.
Also with noise you have to do all of the barrier and you would only be doing a small part.
Please keep us updated of what you do.
I thought the stock ones are Ali?
1 hour ago, ianmayco68 said:
I might have a pair knocking about in the shed Ross, I’ll have a look when I go out. Thought I’d answered your wanted add , sorry mind on other things at the minute, so must have forgot.
I found a pair last night on eBay, round the corner from a mate. But thanks anyway!
  • Like 1
