Rear Door Aperture - Depth measurement
I'm having some issues with the fitment of the replacement rear panels on my tub, either side of the door. The problem stems from the depth of the return thats folded into the panel for the rear door seal. My old panel gives me about ~16-17mm from the rear face of the panel to the face of the seal part. But the replacement panels have about a 20mm step which means they then don't line up with the back edge of the wheel box or the bottom/back edge of the tub.
A couple of friends have measured later tubs:
  • 19mm on a Puma
  • 19mm on an N-reg 300tdi
  • '03 Td5 he's going to remeasure as he came back with 16 but that doesn't tally up being in the middle of the above ages!
So what year have you got and whats the dimension?
