Keeper96 Posted May 9, 2021 Share Posted May 9, 2021 Hi all, the bushes/connectors on my transfer box linkage have worn so that I can’t control the diff lock via the lever, I have to go underneath and do it manually. ive adjusted the linkage and I can get either engage or disengage but no both as the worn bushes takes up the movement of the lever. does anyone have a part number for these and can they be changed in situ? Or is the box coming out? I would normally pull the tunnel out but I’ve fitted WOR matting and I’m never removing that again haha thanks Jamie Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 9, 2021 Share Posted May 9, 2021 FRC4499 I think is what you're after , I bought the ones I got from Britcar I think . As for changing them in situ I've never tried but may be fiddly . Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 9, 2021 Share Posted May 9, 2021 WOR matting out Jamie 🤣 Mo 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 10, 2021 Share Posted May 10, 2021 I had this issue some years back, tried several brands of the bushes, gave up and made some from Bronze, linkage has been spot on ever since. 2 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2021 Share Posted May 10, 2021 If you measure them nylon top-hat bushings can be had for cheap as a generic part on ebay etc. for standard sizes like M6 or M8 bolts. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted May 12, 2021 Share Posted May 12, 2021 I did this a couple of weeks ago after I suddenly lost one of the clevis pins even though the clip was on properly. you can do this with the tunnel in just by removing the the gearstick rubber gaiter and the foam insulator. I then held the hi lo lever tight with a bungee cord and did most of it from underneath with a pair of long nose pliers. Occasionally you need to tweak from above. Having the gaitor off and the insulator out gives you much better light and visibility when working from below. Use a bit of grease to hold the bushes in position and you can do it. I can assure you though that there will be some cussing and swearing!! Toby Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 13, 2021 Share Posted May 13, 2021 I was forever trying to do jobs like this with awkward bits of body or trim in place. Then I had an epiphany and realised that if I spent half an hour removing things like the WOR matting the job would be 50 times faster, I would get less stressed about fiddling around in small spaces to do a simple job and skinning any bare skin in the process. Just remove the matting - its not that much of a ballache to get out. Then with the transmission tunnel out of the way the actual job you want to do will take 5 minutes. You can dry under the matting whilst it is out too as its bound to be soaked under there... Quote Link to comment Share on other sites More sharing options...
