Mossberg Posted March 9, 2022 Share Posted March 9, 2022 2 hours ago, Gazzar said: Any photos? Of the rust or the helicoils? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 9, 2022 Share Posted March 9, 2022 Rust! It might be fixable. 1 Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 9, 2022 Share Posted March 9, 2022 41 minutes ago, Gazzar said: Rust! It might be fixable. I will take a photo tomorrow. I would value your opinion as if it's fixable I should be able to do it. Because it's the axle I don't know anything about it. Obviously I can measure the diameter etc, but I am not sure about it's material thickness etc. Also this must be one of the most structural parts so it has to be right. I can add strength to it but then is a second hand casing not better - obviously this would be cost dependent. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 9, 2022 Share Posted March 9, 2022 Depends on your welding. A second hand good axle should swap in. That's quick, and might be inexpensive. A good weld repair might be just the same amount of time, and be a lot cheaper. 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 10, 2022 Share Posted March 10, 2022 When I put 90 calipers on my RRC axle there is definitely a difference in bolt dia, with imperial bolts the caliper would rattle when loose, test fitted with tube shims to ensure bolt spacing was OK, then helicoiled to match new 90 bolts and all is good. Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 10, 2022 Share Posted March 10, 2022 12 hours ago, Gazzar said: Depends on your welding. A second hand good axle should swap in. That's quick, and might be inexpensive. A good weld repair might be just the same amount of time, and be a lot cheaper. Best photo I can get until I crawl under the truck. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 10, 2022 Share Posted March 10, 2022 Okay, looking like a new axle .... Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 10, 2022 Share Posted March 10, 2022 4 hours ago, missingsid said: When I put 90 calipers on my RRC axle there is definitely a difference in bolt dia, with imperial bolts the caliper would rattle when loose, test fitted with tube shims to ensure bolt spacing was OK, then helicoiled to match new 90 bolts and all is good. I measured the bolts that came out and went back back in. The ones that came out were M12x1.25 and M12x1.75. Initially I assumed the coarse threads were imperial but they were not. The replacements were the same. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 10, 2022 Share Posted March 10, 2022 2 hours ago, Mossberg said: Best photo I can get until I crawl under the truck. Blimey. Did it used to live in the sea?! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 10, 2022 Share Posted March 10, 2022 If that's the bumpstop pad, then what are the diff pans like? Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 10, 2022 Share Posted March 10, 2022 20 minutes ago, landroversforever said: If that's the bumpstop pad, then what are the diff pans like? I will take some photos later. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 10, 2022 Share Posted March 10, 2022 1 Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 10, 2022 Share Posted March 10, 2022 Not sure why this is upside down. Whilst this is quite messy due to the underseal, it's not like the area between the bumpstop and axle case. That area had obviously been filled with crud and not cleaned creating a moisture trap. I suppose the lesson here is the parts that will rot are the parts that don't get cleaned and treated. Quote Link to comment Share on other sites More sharing options...
