92a Posted July 31, 2021 Share Posted July 31, 2021 It curves round it on both of mine Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted July 31, 2021 Author Share Posted July 31, 2021 Having problems pressing out. The old bush.. does it press out just the rubber or should it come out with a sleeve aswell ?? Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted July 31, 2021 Author Share Posted July 31, 2021 44 minutes ago, 92a said: It curves round it on both of mine See that makes sense.. how come mine was curving other way then ?? Quote Link to comment Share on other sites More sharing options...
92a Posted July 31, 2021 Share Posted July 31, 2021 Not sure why your’s was round the other way ? but if you’re pushing out original bushes you can push the centre metal sleeve and rubber bit out then cut the “outer” sleeve to weaken it and collapse it inwards ( don’t cut into or damage the panhard rod ) Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 31, 2021 Share Posted July 31, 2021 It’ll be obvious when you fit it; that bend is specially to clear the diff pan, so is on the vehicle’s right side and bows toward the bumper. I’m not sure if left hand drive vehicle have that bow in the rod. 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 31, 2021 Share Posted July 31, 2021 It’s left hand drive vehicles that need the bend in the rod, on a right hand drive that side of the rod is on the chassis bracket which is further forwards but on a left hand drive that side is on the axle bracket further aft and right close to the diff, so the bend is needed to clear it. That’s why on the later 2002-on rods the RHD version is a straight tube but the LHD still has the bend. It’s just that on earlier models they only had one common part, so on RHD the bend is superfluous. 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted July 31, 2021 Author Share Posted July 31, 2021 Just now, Retroanaconda said: It’s left hand drive vehicles that need the bend in the rod, on a right hand drive that side of the rod is on the chassis bracket which is further forwards but on a left hand drive that side is on the axle bracket further aft and right close to the diff, so the bend is needed to clear it. That’s why on the later 2002-on rods the RHD version is a straight tube but the LHD still has the bend. It’s just that on earlier models they only had one common part, so on RHD the bend is superfluous. Yep so that does make sense for the blue arrow on pic is the side that goes nearest diff Quote Link to comment Share on other sites More sharing options...
western Posted July 31, 2021 Share Posted July 31, 2021 blue arrow side goes in front of the diff housing, so the rod moves away then back in to avoid the diff. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 1, 2021 Share Posted August 1, 2021 18 hours ago, Chambo110 said: Having problems pressing out. The old bush.. does it press out just the rubber or should it come out with a sleeve aswell ?? With a press you will need a something that is exactly the OD of the bush so that the outer sleeve is pushed out with the rest of the bush, as one piece. It is quite thin and even hard to see. I haven't access to a press so reverted to a common method to hacksaw from the middle, through the tube, then the rubber and finally the outer sleeve. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted August 1, 2021 Author Share Posted August 1, 2021 10 minutes ago, Peaklander said: With a press you will need a something that is exactly the OD of the bush so that the outer sleeve is pushed out with the rest of the bush, as one piece. It is quite thin and even hard to see. I haven't access to a press so reverted to a common method to hacksaw from the middle, through the tube, then the rubber and finally the outer sleeve. All done.. used hole saw through rubber then just had to “carefully “ hacksaw outer sleeve til I could break it free. No damage to rod so all good. just checking.. is 88nm sound correct for putting back on? Thanks again fellas.. another job out the way Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 1, 2021 Share Posted August 1, 2021 (edited) Done in six minutes or maybe you'd already figured it out 🤣. Can't confirm the torque but google confirms this, from the LandRover Workshop site - which I would trust. https://www.lrworkshop.com/torque-specifications-settings/land-rover-defender-1996 Edit: don't know why the page isn't being previewed in that link Edited August 1, 2021 by Peaklander 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted August 1, 2021 Author Share Posted August 1, 2021 6 minutes I wish 🤣 All torqued to 88. Great link thanks. That will come in very handy 1 Quote Link to comment Share on other sites More sharing options...
