JeffR Posted March 14, 2022 Share Posted March 14, 2022 I need some new front door hinges, bought some a few year back (yes in a blue box....), retrieved them from them their resting place only to find they have more slop than the old ones. Can anyone recommend a supplier, not interested in go faster ones that cost more than a new door, just common or garden hinges Quote Link to comment Share on other sites More sharing options...
dave88sw Posted March 15, 2022 Share Posted March 15, 2022 I assume the ones you bought are the earlier square type? I've never found a decent reproduction of those, like you say, they have more slop than the one you remove normally. Britpart or bearmach versions of the later slightly rounded hinge are actually more than acceptable and quite good value. Quote Link to comment Share on other sites More sharing options...
JeffR Posted March 15, 2022 Author Share Posted March 15, 2022 cheers Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 15, 2022 Share Posted March 15, 2022 There used to be re-pinning kits. I doubt it would be that difficult to re drill them and fit new pins and bushes probably need a lathe though. Mike Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 20, 2022 Share Posted March 20, 2022 I have an old Oneten with S3 doors. I found, that the new hinges are slightly biger than the old ones. The upper hinges will not fit under the cappings of two part doors. Drillings and their distances are exactly the same. Best way (what I did 10 years ago) is to drill the old hinges completely to 8mm and put a new 8mm bolt in. This worked for 10 years now. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 20, 2022 Share Posted March 20, 2022 3 hours ago, Sigi_H said: I have an old Oneten with S3 doors. I found, that the new hinges are slightly biger than the old ones. The upper hinges will not fit under the cappings of two part doors. Drillings and their distances are exactly the same. Best way (what I did 10 years ago) is to drill the old hinges completely to 8mm and put a new 8mm bolt in. This worked for 10 years now. You could trim the inner face of the hinge to make a notch along its top edge to account for the capping. Milling would be ideal, but a slitting disc on a grinder would suffice. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 20, 2022 Share Posted March 20, 2022 I know. But the hinges are nicely galvanized and I still struggle to destroy the surface Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 21, 2022 Share Posted March 21, 2022 The zinc would still be effective even breached, but with a good coat of primer and paint and a dollop of grease, there is no way that notch would rust. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 22, 2022 Share Posted March 22, 2022 I don´t want to paint them Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 22, 2022 Share Posted March 22, 2022 11 hours ago, Sigi_H said: I don´t want to paint them I think I just doubled up the plastic spacers on both sides of the hinge when I had the issue with the newer type fouling on the galvanised door capping. It doesn't take much to make them clear on the early 90/110 doors, though I'm not sure if the capping on a series 3 door is the same thickness. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 23, 2022 Share Posted March 23, 2022 When I remember wright, it was about 3 to 4 mm to double them up. That was a bit to much for me. I keep thinking about it. Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 23, 2022 Share Posted March 23, 2022 14 hours ago, Sigi_H said: When I remember wright, it was about 3 to 4 mm to double them up. That was a bit to much for me. I keep thinking about it. Ahh okay, that may be too much. I only had to use 2 per side, instead of the standard 1. Quote Link to comment Share on other sites More sharing options...
