Stellaghost Posted February 17, 2023 Share Posted February 17, 2023 Thought I would start this as a new topic so it keeps it altogether, maybe someone in the future may want to do the same, who knows ( that's assuming it actually turns out ok ) Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 17, 2023 Author Share Posted February 17, 2023 So a quick recap, this is where myself and Gazzer are at A lucky piece of scrap plate This will not be a quick process, after all Sid is the main priority at the moment.....lol Regards Stephen Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 17, 2023 Share Posted February 17, 2023 I'm excited! And grateful. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 17, 2023 Share Posted February 17, 2023 Photos. Of a fairlead. From the internet. Very different from the usual. For those who've not seen one before: Designed for the 101 nokken capstan winch that's bolted to side of the chassis between the wheels, driven by a side PTO on the transfer box. Cable normally strung along the chassis to the front. The fairlead can be unclipped and moved to the back as required. The cable rerouted to match. Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 17, 2023 Share Posted February 17, 2023 Looking at that now, it looks fairly similar to regular heavy recovery winch sheaves. Like in this picture: In fact, this looks like pretty much the same thing: https://wintech-winches.com/swivel-fairleads/ 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 17, 2023 Author Share Posted February 17, 2023 A little bit of progress Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 17, 2023 Share Posted February 17, 2023 Wow! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 19, 2023 Author Share Posted February 19, 2023 @Gazzar did you invoke the gods of wind and rain ???? Anyway it worked to your advantage 20230219_091948.mp4 Regards Stephen 1 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 19, 2023 Share Posted February 19, 2023 Wow! It's sunny here, but I'm in the workshop regardless. I hope the weather clears up for you soon. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 19, 2023 Share Posted February 19, 2023 I'm really looking forward to seeing this. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 19, 2023 Share Posted February 19, 2023 On 2/17/2023 at 8:39 AM, elbekko said: Looking at that now, it looks fairly similar to regular heavy recovery winch sheaves. Like in this picture: In fact, this looks like pretty much the same thing: https://wintech-winches.com/swivel-fairleads/ And they're just welded together. Very interesting. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2023 Share Posted February 21, 2023 On 2/19/2023 at 5:30 PM, Gazzar said: And they're just welded together. Very interesting. Probably not with a SIP HobbyMig though Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 21, 2023 Share Posted February 21, 2023 Would hope not. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 21, 2023 Share Posted February 21, 2023 The more you look : ACE Swivel Head Fairleads (ace-winches.com) Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 25, 2023 Author Share Posted February 25, 2023 Hmmm I keep saying a build, but is it a build, I'm not building I'm removing Could it be a carving or a sculpture What do you think....? Regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted February 25, 2023 Share Posted February 25, 2023 Possibly a re-creation/recreation? Steve Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 25, 2023 Share Posted February 25, 2023 I think it's visualisation. Seeing the shape of the fairlead that exists in the lump of steel. That's sculpture. Creation. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 26, 2023 Author Share Posted March 26, 2023 A bit more progress First drilled holes where pulleys will sit, drilled and tapped for m12 they will eventually be drilled out to complete size which is 16mm why drill and tap ? I needed a means of holding failead in bandsaw to be able to cut a section out to reduce milling time bracket to hold fairlead Now to start cutting, need to remove a slice 20mm thick, finished thickness will be milled out to 22.5mm Turned around Cuts finished, now drilled in from each side slice removed, saying it is a lot easier than doing it..lol happy with that.. to be continued regards Stephen 3 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 26, 2023 Share Posted March 26, 2023 THAT'S how you did that! I would not have thought of doing that. Band saw! I had visions of milling it and all sorts of madness. Brilliant. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 26, 2023 Author Share Posted March 26, 2023 37 minutes ago, Gazzar said: THAT'S how you did that! I would not have thought of doing that. Band saw! I had visions of milling it and all sorts of madness. Brilliant. Still got milling to do to widen gap, using the bandsaw first will cut down on milling time Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 28, 2023 Author Share Posted March 28, 2023 Coz I've got nowt better to do...... 20230328_191444.mp4 Regards Stephen 2 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 28, 2023 Share Posted March 28, 2023 I could watch that all day. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 28, 2023 Author Share Posted March 28, 2023 5 minutes ago, Gazzar said: I could watch that all day. I will be..........lol Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 28, 2023 Share Posted March 28, 2023 It's a joy to see a piece being created. I don't know why, even my crude welding and shaping of steel into something useful is satisfying at a deep level. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 28, 2023 Author Share Posted March 28, 2023 1 hour ago, Gazzar said: It's a joy to see a piece being created. I don't know why, even my crude welding and shaping of steel into something useful is satisfying at a deep level. Agree with that, I still get and always will get a kick out of making stuff Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
