fmmv Posted April 1, 2023 Share Posted April 1, 2023 Does anyone happen to know if the 4 pinion diff in late model 110 and 130 front axles fits in normal long nose diff front and rear? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 1, 2023 Share Posted April 1, 2023 The main diff pumpkin itself is different. With machining work the centre can be made to fit a long nose case. But for the effort you'd be better off buying something like the ashcroft ATB. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 1, 2023 Share Posted April 1, 2023 Did they use the short nose in the front as well @landroversforever? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 1, 2023 Share Posted April 1, 2023 4 minutes ago, Bowie69 said: Did they use the short nose in the front as well @landroversforever? Doh! Missed the front axle bit.... the fronts are normal 2 pins as far as I know. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 1, 2023 Share Posted April 1, 2023 1 hour ago, fmmv said: Does anyone happen to know if the 4 pinion diff in late model 110 and 130 front axles fits in normal long nose diff front and rear? The 110 and 130 used the same front diff as the 90, RRC and Discovery 1, ie the long nose Rover diff. They weren’t reinforced. The 4-pin short nose diff of the P38 was only used in the rear axles of 110s and 130s once the Salisbury was axed in 2002, about the same time as the dash changed to the black plastic fascia with centre console and the doors changed. As to whether you can fit those diff centres to a long nose casing, or fir a short nose complete diff and casing to a standard axle, not without considerable modifications. 1 Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 1, 2023 Author Share Posted April 1, 2023 The parts book suggest there is a 4 pinion diff in the front of 110 and 130, 2012 models anyway. I didn't think it was the short nose I must admit, It didn't think there were steerable versions. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 1, 2023 Share Posted April 1, 2023 I missed the mention of front to be honest! The front diff is a normal long nose. I don't know of anything with the short-nose in the front of anything. Got any images from the parts book? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 1, 2023 Share Posted April 1, 2023 Or part numbers? Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 1, 2023 Author Share Posted April 1, 2023 Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 1, 2023 Author Share Posted April 1, 2023 The front propshaft is TVB500500 for all variants so I assumed the nose length is the same; maybe I'm wrong. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 1, 2023 Share Posted April 1, 2023 1 minute ago, fmmv said: The front propshaft is TVB500500 for all variants so I assumed the nose length is the same; maybe I'm wrong. I wonder if the front 4-pin was an option. But either way, the centres which fit in a short nose casing don't fit a long nose without buggering about with machining work, but a long nose 4-pin from the front (or like a 90 V8 rear) fits in the front/rear of all 90/D1/D2/RRC. Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 1, 2023 Author Share Posted April 1, 2023 (edited) The parts book suggests 2 pin on 90s front,4 pin on the others. Its probably basically a 90 v8 rear then Edited April 1, 2023 by fmmv Quote Link to comment Share on other sites More sharing options...
uninformed Posted April 2, 2023 Share Posted April 2, 2023 The original Defender used long nose Rover diffs until it’s death in 2016 ok, let’s ignore the rare variants with Sals front for this discussion The 4 pin HD hemisphere was an option for a VERY long time ( just like ENV, then Sals rears were an option on Series before their standard fitment) I can not confirm if LR factory fitted the 4 pin front diff in 110/130 from 2012 onwards. I personally would be surprised as LR were cutting corners everywhere on the last of the old Defr’s But anything is possible. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted April 2, 2023 Share Posted April 2, 2023 4 hours ago, fmmv said: The parts book suggests 2 pin on 90s front,4 pin on the others. Its probably basically a 90 v8 rear then Yes, a Rover hemisphere is the same front or rear. So all factory Rover 4 pin hemispheres are the same. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 2, 2023 Share Posted April 2, 2023 10 hours ago, fmmv said: The parts book suggest there is a 4 pinion diff in the front of 110 and 130, 2012 models anyway. I didn't think it was the short nose I must admit, It didn't think there were steerable versions. I’m confident though not certain that 110 and 130 have a big standard single pin front diff, identical to contemporary 90s. 4-pin may have been an option at one point, but probably dropped a long time before the end of production. Quote Link to comment Share on other sites More sharing options...
uninformed Posted April 2, 2023 Share Posted April 2, 2023 I heard back from a mate here in Oz that is in the game. No 4 pin diffs factory fitted to 110/130s 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 3, 2023 Share Posted April 3, 2023 Mistyped “bog standard” in my last post. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 12, 2023 Share Posted April 12, 2023 My mid-2015 2.2 110 definitely only has a 2 pin front diff made of cheese, as I can see it through the 'ole. I understand probably also has a poverty spec centre diff in the late models as well. Deep joy. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 12, 2023 Share Posted April 12, 2023 They did fit 4-pins to the fronts of some late 110/130 models, in response to the issue of 2-pins failing under the higher torque of later Tdci engines. There appears to be no rhyme or reason as to which vehicles got them though or which did not. This is a different diff to the short-nose ‘P38’ diff fitted to the rear axle of 110/130 from around 2005 onwards following the demise of the Salisbury. If you do find one then it should be the same as the old V8 90 rear (heavy duty) diff and so yes should fit into any normal long nose Rover casing. 2 Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 12, 2023 Author Share Posted April 12, 2023 Does seem rather odd, to at least consider fitting a 4 pin diff in the front, but also to go to a 2 pin diff in the transfer box. I think the former is response to failures, the latter is attempts to reduce the 'standard cost'. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 13, 2023 Share Posted April 13, 2023 10 hours ago, fmmv said: Does seem rather odd, to at least consider fitting a 4 pin diff in the front, but also to go to a 2 pin diff in the transfer box. I think the former is response to failures, the latter is attempts to reduce the 'standard cost'. The HD front diffs being so random shows that it wasn’t a deliberate change of spec in response to a demonstrated weakness. By that stage, they were just using up what stock they had left, with no lines using that or the lighter single-pin diff after Defender ceased. Cost engineering mixed with management apathy. 1 Quote Link to comment Share on other sites More sharing options...
