Cannot Get Transmission Brake to Hold
I know that this is covered by many threads, but nothing seems to work!
LR90 Defender 1989 - The back story - at the last MoT the landy only just passed on handbrake with the comment it will need looking at sooner rather than later! So, on that basis, I ordered new shoes. Today I had a look at the handbrake. On removing the drum, it was clear why there were problems - very greasy shoes! Everything was removed (a few bits from the expander fell out), I cleaned the drum and backplate, re-assembled and it was worse then ever.
Removed it all again having read there is a specific way to reassemble the expander!  Took the back plate off and on my bench, removed all the parts to the expander, cleaned, greased and reassembled, holding it all together with an elastic band!
Re-assembled it all back on the car and the handbrake lever is at the maximum extent and it barely holds. So we have:
  • New shoes
  • Expander assembled correctly
  • Handbrake cable on the very last threads at the drum end
And still I cannot get the handbrake anywhere close - a gust of wind will move it !
It's almost as it the cable is too long, it is a newish cable and hasn't had much use and it was OK at one time (so I doubt if it has stretched)
So, what is so obvious I'm missing it?
Thanks in advance
Peter
I've just put the car away, but by the fact that I am at the extreme of the thread at the brake end and I have to go to almost the extreme travel of the handbrake before even a slight resistance is felt - too much!  It's almost as if it is too long at the brake end from the end of the thread. I am not sure if there are different handbrake cables?  The other question - the adjuster opposite the expander - moved until I could hear it rubbing then backed off. The shoes are also in the correct way round!
Edited by Puffernutter
When you say everything inside was greasy - I take it you meant the shoes and you have now fitted a new oil seal?
Also on the early style handbrakes, they can have a lot of wear on the operating lever that the cable attaches too, its hinge and the expander mechanism, meaning you have to move the handbrake lever a long way before the shoes even start to move. Add that to a stretched cable and you'll struggle to get much to happen. Whip the drum off, get an assistant to pull the lever on & off and have a look at what's happening - the shoes should start to move as soon as the lever is pulled.
  • Like 1
Yes and yes. I love the phrase "whip the drum off" which = chock the front, jack up the rear and put in axle stands, remove 4 nuts and 4 nuts and bolts then two cross head screws.  All whilst lying underneath 🙂
However, I take the point about the wear on the operating mechanism!  I do wonder if it is wear on the piece that fits in the expander that is some of the problem.
Peter
Is the handbrake the early linkage type? I had the transfer case off recently and I took the handbrake mechanism apart to service it. The adjuster is pretty straight forward, its just a threaded cone and 2 siders, can't go wrong with the installation. However if you took the expander apart it's quite difficult to reassemble under the car. There are 2 small rollers which if not correctly positioned will not expand the brake.
  • Like 1
Hello, it's not that early. It has the square end and no threaded cone that I could see! The expander, I realised when the parts fell out it wasn't simple in the car, so I took off the backplate and cleaned everything and re-assembled it correctly - at least the two parts seems to move slightly when the central rod was operated.
A question for the collective, in case there is too much wear in my expander I have bought another, with the three sliding clips - what order do they go in? There seems to be two sliding clips (I assume one from the top and one from the bottom) bit where does the "space go? In between them, at the bottom, on the top? I've looked and cannot find any information!
Peter
The "pistons" should move quite a distance - how does the new pre-assembled one compare?
clips
515468 plate- spring to back plate from top
515467 plate- locking next from bottom
515470 plate- packing finallly from bottom.
The boot 515466 then fits over the edge of 515467
hth
Steve
clips
hth
Steve
Movement - I'll let you know when it arrives. I only ordered it last night! On the one I have, I didn't see much movement at all to be honest and I double checked I had the pistons and the rollers in the correct way round!
Peter
The expander is held by the spring clips, the manual adjuster on the other hand is bolted. This is the early cable/linkage type handbrake.
It took me a while to assemble the adjuster correctly, my mistake was I had the plungers 180° off, so when I pulled on the linkage, I had little to no movement on the plungers. Took them apart and rotated them and immediately the travel was much larger.
This thread might be of interest.
Edited by muzaz
Added a link
