Paddy_SP Posted February 26 Share Posted February 26 I had to do some work on my 110's doors today and was rather unimpressed to find that the PU adhesive that I'd previously used to bond the window clips to the glass had failed. I don't remember exactly what it was, but it's white. So - is Tiger Seal the preferred solution, or is there some other product I should be looking at? As ever, any help would be most appreciated! Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 26 Share Posted February 26 There is proper glass adhesive. I think you’d get neater and stronger results with that. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted February 26 Share Posted February 26 Marine bond might work, it’s what they use to bond the glass into fish tanks, I used some to bond aluminium sheet to the back of my side panels to make them like utility ones been on 10 years now. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 26 Author Share Posted February 26 Thank you, Gentlemen - much appreciated! Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 28 Share Posted February 28 Just done this (for the umpteenth time....) used glass adhesive acquired from a mate who fits windscreens). He uses very fine wet and dry to "rough up the glass" in the contact patch. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted March 7 Author Share Posted March 7 I bought some Masterbond windscreen adhesive - but although it sticks to the glass, it just falls off the plastic. Anyone know what LR used originally? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 7 Share Posted March 7 Our trim guy at work uses a brush on window acid etch solution which comes in a little bottle, leaves it a day then uses a tiger seal type pu adhesive, but plenty of it, in the joint and over the back of the plastic , then leaves it to fully cure over the weekend. They come out rock solid. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted March 7 Author Share Posted March 7 There doesn't seem to be a problem with adhesion to the glass - it's the damned plastic that's causing the problem! Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 7 Share Posted March 7 That is peculiar. Have you tried keying the plastic surface, or even cleaning it with acetone to make sure it has not contaminates? Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted March 7 Author Share Posted March 7 The problem is that the part that needs cleaning is almost inaccessible due to the combination of a narrow gap and internal ribs. My mate uses Sikaflex 292 on his boat and swears by it, so I may purchase a tube of that (if I can get a mortgage on it, that is...). Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 8 Share Posted March 8 I have previously used sika 291, as the clips are completely hidden you can smear it all over the clips and glass! Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted March 8 Author Share Posted March 8 Yes, that was my plan - expensive stuff though! Quote Link to comment Share on other sites More sharing options...
