Retroanaconda Posted March 3 Share Posted March 3 Vapour garage build ongoing here… Let's say I was to build a workshop and have provision for a ramp (likely a 4-post). What would be a sensible clearance height requirement to allow for its use? Obviously I can just add the height of the vehicle to the ramp’s maximum lift as a simple measure but is there anything else to consider? Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 3 Share Posted March 3 Bonnet height in case it makes the vehicle higher. For example on the P38 the bonnet in service mode (straight up) is a good bit higher than the roof. 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted March 3 Share Posted March 3 We're working on 4,50 mtrs. between floor and underside ceiling / trusses etc. for our workshop. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted 2 hours ago Share Posted 2 hours ago It's a little more work on the slab front but it is worth considering sinking the lift in so the ramps are flush with the main floor. Gains you a few inches and makes putting normal cars on it far easier. It also means than any oil spills etc., are likely to be contained rather than going off under benches etc. You could always provision a drain inside there as well. For other reasons I installed an aqua channel around two walls of my workshop (ground behind them is significantly higher). I've not had an issue with water ingress through the wall because of the drainage work we did in the neighbours yard but it's been handy when I bring a wet vehicle in to be able to sweep the water that drops off into the drain. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted 2 hours ago Share Posted 2 hours ago A sunk lift is OK, but if you are planning on rolling hoists or jacks around in the same space it becomes a massive pain. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted 1 hour ago Share Posted 1 hour ago I’d always pick a surface mount rather than sunken. You’ll always end up tripping over the edges, and majes stuff like transmission jacks or oil drain units a total pain. If you’re likely to be tight on heigh then working out what the highest working height you might need is helpful. IE not having to lift as high with a Land Rover as you’ve got the underbody clearance to think about. Also depends on the height of the person working on stuff! Quote Link to comment Share on other sites More sharing options...
