Best Rover Sump Gssket
What’s the latest technology (lol) in the area of Rover V8 sump gaskets ?
1994 4.2 rover V8 non serp.
Cork gasket  and be careful not to over tighten ?
Cork and rubber gaskets leak in the long term, also the sump flange needs to be perfect, and need to be tweaked up bit by bit, and not overtightened.
RTV far better. Clean and degrease both surfaces, along with all the bolts, and it will not leak.
I hate oil dripping engines. I use red HTR 430
  • Like 1
But don't use more Rtv than you have to, I think LR say a 2 mm bead, it squeezes out and blocks the strainer. I let it go off for a bit before tightening beyond finger tight.
  • Thanks 1
So how much CPU thermal paste, sorry I mean RTV is exactly the right amount ?
Internet as usual seems to have varying views with the joyful rtv broke off got stuck the oil feed and wrecked the engine stories to help raise the stakes.
