FridgeFreezer Posted March 12, 2007 Share Posted March 12, 2007 I need a brake system for the 109, with a servo. I have a stock 109 pedal box but the servo & m/c were removed and used on another vehicle (coughJAMESMORFEEcough) so I need to source a replacement. The 109 will have discs all round. I have played with a RR servo at the lab but it doesn't fit. So, what I need is a setup that will fit a Series/defender bulkhead (I don't mind cutting the wing a bit) and give a decent amount of assistance. If anyone has a setup for sale locally (Portsmouth) I'd be interested. Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 12, 2007 Share Posted March 12, 2007 Fridge, early defender (smaller diameter servo) will bolt straight to your bulkhead and take a defender master or late series 3 one and u'll still be able to shut the series bonnet, if u fit later defender then it has bigger diameter servo and u'll have to fit a power bulge in your bonnet to get it to shut Quote Link to comment Share on other sites More sharing options...
Lewis Posted March 12, 2007 Share Posted March 12, 2007 I've got a series servo assist master cyl and pedal box assy you are welcome to Fridge, not exactly local to portsmouth though Lewis Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 12, 2007 Share Posted March 12, 2007 i think i've got a series pedal box and servo, i'll have a look (obviously very local to portsmouth) Quote Link to comment Share on other sites More sharing options...
JST Posted March 12, 2007 Share Posted March 12, 2007 i've got a def early vacum servo and master cylinder. Quote Link to comment Share on other sites More sharing options...
pugwash Posted March 12, 2007 Share Posted March 12, 2007 stage 1 V8 master servo would give you a load of assistance and would fit perfectly- don't think the master cylinder would be suitable though as it's a large bore design specfically for the large slave cylinders. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 12, 2007 Author Share Posted March 12, 2007 Tonk is in the lead currently 'cos he's closest assuming he finds the bits in his spotlessly tidy garage since the setup is a bit of an unknown I will run with whatever arrives first for the MOT and if it's horrible I'll re-visit as time/money allows. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted March 13, 2007 Share Posted March 13, 2007 Discs all round, I had trouble with series servo, had to change to a defender one as there was not enough assistance. I think Tonk and Jon White had the same problems. Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 14, 2007 Share Posted March 14, 2007 Yep - we're both running early 110 servo and pedal box with the series master cylinder. Series one works well enough, but doenst offer enough servo assistance - you still need both feet on the pedal to get it to stop! 110 one makes a world of difference, but as mark says - dont get a late one cos the bonnet then doesnt close! (guess how I know!) Jon Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 14, 2007 Share Posted March 14, 2007 This is a very interesting thread as I am looking for a low profile servo (ie fits under bonnet) for my series hybred, I have RRC twin pipe 4 pot calipers on the front, will early Def work for this? If so is there a spare set left on this thread after Fridge and how much? Cheers, Quote Link to comment Share on other sites More sharing options...
