Talyllynman Posted March 29, 2007 Share Posted March 29, 2007 There seems to be a theory that adding a lubricant to diesel fuel is a good idea with modern low sulphur fuel to reduce wear in the injection pump. Millers seem to do some, though at the moment I have not found anywhere that stocks it. What do folk use, if anything? Thanks, Ian Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 29, 2007 Share Posted March 29, 2007 Millers for me though I cannot honestly say I notice much difference between when it is in there and when it isn't... Quote Link to comment Share on other sites More sharing options...
pinny Posted March 30, 2007 Share Posted March 30, 2007 can any one tell me who stocks millers thanks is it available in essex Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted March 31, 2007 Share Posted March 31, 2007 http://www.millersoils.net/ loads in Essex you can search on he site Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted April 1, 2007 Share Posted April 1, 2007 Bosch rotary injector pumps as used in the Tdi engines, can be destroyed by low sulpher diesel. The first symptom is failing to stop when you switch off, remove the stop solenoid and it will be covered in swarf. The best and cheapest option is to run it on at least 10% veg oil, mine is running on 60% Peugeot know about the problem and in some countries advise the use of additive. In France this is why all diesel is 5% bio. Quote Link to comment Share on other sites More sharing options...
tio Posted April 8, 2007 Share Posted April 8, 2007 There seems to be a theory that adding a lubricant to diesel fuel is a good idea with modern low sulphur fuel to reduce wear in the injection pump. Millers seem to do some, though at the moment I have not found anywhere that stocks it. What do folk use, if anything?Thanks, Ian personaly ive all ways used some red for this reason a tankfull occaisonally does wonders so long as ukeep on top of your filter's and dont get dipped of course! Quote Link to comment Share on other sites More sharing options...
pinny Posted April 22, 2007 Share Posted April 22, 2007 ive been adding millers for about 2 weeks now done about 400 miles cant say as ive noticed any difference maybe its doing some good lubricating pump Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2007 Share Posted April 22, 2007 the latest parts from Bosch to overcome the swarf problem have cured my 200Tdi's running on when switched off. Quote Link to comment Share on other sites More sharing options...
MRWOO Posted April 22, 2007 Share Posted April 22, 2007 Ive used both Millers and Lucas Upper Cylinder cleaner's I started off with the Lucas which made a siginificant difference to my 300 Defender. It ran much quieter, better performance and about 2mpg more which off set the price of 2p per litre extra. After using it for about a 1000 miles I switched to try the millers which I thought was a waste of money no increase in mpg no reduction in black smoke under hard acceleration, nothing. I think the only reason I tried was because it works out about 1p per litre against the Lucas's 2p and they sell it in my local LR shop. For those interested I used to order my Lucas from Redmans engine centre in 1Litre bottles for £15. I would start off buying the one shot version 155ml and stick the lot in a full tank. Lucas recommend 155ml for 25 gallons and say that you cannot overdose the engine on it, mine always ran better on the double dose and it was always easier to work out how much to put in consistently i.e 1 small bottle wich I kept filling from the 1 litre bottle http://www.redmansenginecentre.co.uk/ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 22, 2007 Share Posted April 22, 2007 Quite a few club members of lower taste use Millers and swear by it, the commonly held belief is that supermarket fuel is skimped on additives to keep it cheap and is bad for TDi's. How true this is I don't know. I've also heard that running a tankfull of BP Ultimate or an equivalent through once in a while is good for things, if bad for the bank account. Quote Link to comment Share on other sites More sharing options...
Abe Posted May 10, 2007 Share Posted May 10, 2007 Hiya When I inported my 300tdi into belgium i brought back some millers - it did seem to make a difference even on the normal every day vehicles a 1.9 renault dti as it more difficult to source so next time over i will stock up What i have found perhaps better than addatives it to fuel all the diesels we run on Bio diesel of the EN14214 norm. Ive found it runs smoother gets better milage - no smoke. & is generally avalable away from the major filling station chains in germany -running twin tanks i fuel it and its good for a month. csts about ,99cnt a litre compared with curent prices of abou Eur 1.15 for anyone interested in general on real bio as opposed to the home-brewed "chip-fat soups" have a look at the link http://www.bioroute.co.uk/biodiesel.htm#Four happy trails Abe Quote Link to comment Share on other sites More sharing options...
