JST Posted October 23, 2005 Share Posted October 23, 2005 just some simple ideas to make life a little easier: a net on the bonnet to stick strops and other light items under between stages: and a slightly different approach to a winch hook on the cage, two exhasut clamps (52mm) bolted back to back witha small plate. save welding onto the cage, removable if needed and can be fitted anywhere onto the cage for less than £5 Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 23, 2005 Share Posted October 23, 2005 Good idea on the exhaust clamps James The best use I've seen for the bonnet net is to stick your plasma into between punches to save winding it back on and then off the winch drum on each use. Steve Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 23, 2005 Share Posted October 23, 2005 The best use I've seen for the bonnet net is to stick your plasma into between punches to save winding it back on and then off the winch drum on each use. A big favourite with us Milemarker boys (I thought I'd get in there before someone else did) I have an idea along yr lines James - watch this space. Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 23, 2005 Share Posted October 23, 2005 James, the bonnet nets a good idea, I've got one but I've not got round to fitting it. I'm about to do something with a wing mounted winch hook but it'll be designed not to damage anything if the cable gets tight Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 23, 2005 Share Posted October 23, 2005 Digger90 could put one of them rings on his roof and use it to pull the truck cab back into place I wind my plasma round the spotlights if I need to get it out of the way for a moment - try doing that with wire rope B) Quote Link to comment Share on other sites More sharing options...
MogLite Posted October 23, 2005 Share Posted October 23, 2005 I'm about to do something with a wing mounted winch hook but it'll be designed not to damage anything if the cable gets tight That is the challenge I face with MogLite, driving off with the PTO engaged and changing the wheelbase Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 23, 2005 Share Posted October 23, 2005 Andy, my first thought was use plastic nuts (like the ones used to hold number plates on), now I'm thinking of using a couple of the rubbers used to mount the air filter box attached to a U shaped peice of stainless bar with a female thread in each prong. Quote Link to comment Share on other sites More sharing options...
simonr Posted October 24, 2005 Share Posted October 24, 2005 What about putting a switch on it so that if the hoop bends, it sounds the horn / cuts engine / connects HT to steering wheel? Si Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 24, 2005 Share Posted October 24, 2005 The problem's that its an 8274 so if it cuts out when the hook begins to bend it'll be too late Quote Link to comment Share on other sites More sharing options...
Mark90 Posted October 24, 2005 Share Posted October 24, 2005 Zip ties or gaffa tape. Works for everything else on a a LR. Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 24, 2005 Share Posted October 24, 2005 Never had a problem with my wing hook and 8274, just fit it Will, I'm sure you'll be ok. Steve Quote Link to comment Share on other sites More sharing options...
Lara Posted October 24, 2005 Share Posted October 24, 2005 These are my Winch Bitches, With these on your team you have no rush at all And certainly do not need help from anyone else Lara. Quote Link to comment Share on other sites More sharing options...
