paradigm shift Posted October 25, 2005 Share Posted October 25, 2005 I'm missing a mudflap on my 110 so I've reached a crucial decision! Do I replace the mudflap, or do I remove them all? I've noticed the other weekend that a lot of people don't have them, yet I would have thought they do a good job keeping muck off the underside of the vehicle (at least a little? ) or do they not really help once you get into the sticky stuff properly and perhaps stop the wheels from throwing off mud from their treads? Quote Link to comment Share on other sites More sharing options...
siggy Posted October 25, 2005 Share Posted October 25, 2005 Personally I'd do both! 1stchange the mounting bolts to stainless with copperslip keep them on for road remove for offroad.................... Quote Link to comment Share on other sites More sharing options...
Mark90 Posted October 25, 2005 Share Posted October 25, 2005 I find they do a good job of keeping muck of the bodywork, but they do tend to get ripped off when reversing off road. On my old 90 I trimmed the mud flaps so they couldn't get gripped against the tyres and ripped off, IIRC I toock abouot 4"-6" off them and they still done a decent job of keeping the truck clean. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 25, 2005 Share Posted October 25, 2005 First thing I do on my vehicles when I get them is chisel them all off because... a) They get ripped off anyway every time you have to reverse into/over/through something interesting b ) on unsurfaced roads frankly they make F all difference, the vehicle is going to get covered in clay anyway c) it is about 4 square feet less of cleaning to do (8 if you count both sides) whenever the pressure washer is called upon If you do want to keep them on though, one thing I have seen some people here do is put a small U-bolt through almost at the bottom of the flap to make a "ring" at the back, then when you go off road you can get a small bungee cord and tie them up out of the way, works quite well to avoid damage. Quote Link to comment Share on other sites More sharing options...
jules Posted October 25, 2005 Share Posted October 25, 2005 a) They get ripped off anyway every time you have to reverse into/over/through something interestingb ) on unsurfaced roads frankly they make F all difference, the vehicle is going to get covered in clay anyway c) it is about 4 square feet less of cleaning to do (8 if you count both sides) whenever the pressure washer is called upon If you do want to keep them on though, one thing I have seen some people here do is put a small U-bolt through almost at the bottom of the flap to make a "ring" at the back, then when you go off road you can get a small bungee cord and tie them up out of the way, works quite well to avoid damage. a b c You could fitt them were they are on a 1985 90 which is level with the outer face of the cross member this if far enough away from the tyre for it not to catch when reversing. Why they moved them back I don't know Quote Link to comment Share on other sites More sharing options...
John_T Posted October 25, 2005 Share Posted October 25, 2005 Mine fell of so I did without them for a while. Truck got really covered in cr*p on the back. I had to put some new ones on due to travelling in Europe where it is a legal must in some places e.g. Slovakia. Good off roading in Slovakia though!! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 25, 2005 Share Posted October 25, 2005 You could fitt them were they are on a 1985 90 which is level with the outer face of the cross member this if far enough away from the tyre for it not to catch when reversing. Why they moved them back I don't know You can, but b ) and c) still apply :) A mud flap when you are doing 50mph+ on wet unsurfaced clay roads, is about as effective as putting a set of 99p plastic protective goggles on when somebody is about to shoot you in the face with a howitzer at point blank range The only good thing about them is on a road with lots of loose gravel, they do stop a lot of the stones pinging out of the tyres and removing windscreen/lights etc from the vehicle behind Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 25, 2005 Share Posted October 25, 2005 I'd remove them, just as BogBuster says, they stop spray and stones being thrown up to the vehicle behind, so therefore without them people wont drive too close! Quote Link to comment Share on other sites More sharing options...
paradigm shift Posted October 25, 2005 Author Share Posted October 25, 2005 Ok guys lots of good info there, I think they'll come off at the weekend, along with the side steps too (which are seized because they never get used!). Over time I can see everything possible being removed from the underside, just more things to get broken and more things to clean.. Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 26, 2005 Share Posted October 26, 2005 You can, but b ) and c) still apply :) A mud flap when you are doing 50mph+ on wet unsurfaced clay roads, is about as effective as putting a set of 99p plastic protective goggles on when somebody is about to shoot you in the face with a howitzer at point blank range The only good thing about them is on a road with lots of loose gravel, they do stop a lot of the stones pinging out of the tyres and removing windscreen/lights etc from the vehicle behind But...they do look "cool" Quote Link to comment Share on other sites More sharing options...
JST Posted October 26, 2005 Share Posted October 26, 2005 steven, 105 or 155 or some dodgy bit of kit down your way? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 26, 2005 Share Posted October 26, 2005 105 or 155 or some dodgy bit of kit down your way? Argies had some 155s, I think our lot probably have some 105s stowed away somewhere just in case they come back! Not sure the difference would be noticeable when viewed through 99p plastic goggles though Never played with any of them but I was allowed a go with a 66mm LAW on my 10th birthday (Nov 82) that was quite a cool pressie for a young lad B) Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 27, 2005 Share Posted October 27, 2005 i have always taken off mud flaps off my trucks before i rip them off. But i have had to put a full set (front and rear) on the misses 90 for aus as it has to have a set by law Quote Link to comment Share on other sites More sharing options...
JST Posted October 27, 2005 Share Posted October 27, 2005 dont reckon there are any 105 down there maybe some 25lbders! 94mm now replaced the 66 Quote Link to comment Share on other sites More sharing options...
McS Posted October 29, 2005 Share Posted October 29, 2005 massive thread hijack ahead, but hey..... not sure about our 105s, but the argies definetly had 105's there - practically the same as ours in fact And LAW is old news - JAVELIN is the way forward!! No way you'd catch me in a tracked tin can these days... McS Quote Link to comment Share on other sites More sharing options...
