ROGUE TROOPER Posted December 17, 2005 Share Posted December 17, 2005 Just on paper at the mo..... no major thoughts hence no problems yet! Quote Link to comment Share on other sites More sharing options...
landrover598 Posted December 17, 2005 Share Posted December 17, 2005 snap Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted December 17, 2005 Author Share Posted December 17, 2005 You shortend the doors, I did it "mini shorty style" and went into the doors! Big factor will be props and how short can I go! I also cut a bit out of the front as you did...this could be fun! Hard top is the way to go (or Truckcab) as this will be minimun cutting. Will handle like a pig! Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 17, 2005 Share Posted December 17, 2005 You might get a good turning circle though Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 17, 2005 Share Posted December 17, 2005 It'll either have a very interesting rear crossmember or the weakest rear end of any Land Rover. You could check all 4 tyre pressures without getting out of the drivers seat. Les Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 17, 2005 Share Posted December 17, 2005 Will handle like a pig! It's going to look like one too.... Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted December 18, 2005 Share Posted December 18, 2005 Just on paper at the mo..... no major thoughts hence no problems yet! I'll certainly keep the anti's happy - it'll take up less road space than a Smart car!!! Quote Link to comment Share on other sites More sharing options...
ibexman Posted December 18, 2005 Share Posted December 18, 2005 Just on paper at the mo..... no major thoughts hence no problems yet! How do you do that??? Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted December 18, 2005 Share Posted December 18, 2005 How do you do that??? Do what??? use Photoshop or shorten a Land Rrover Quote Link to comment Share on other sites More sharing options...
simonr Posted December 18, 2005 Share Posted December 18, 2005 Do what??? use Photoshop or shorten a Land Rrover I see wheelies on hill-climbs coming! (a bit like a certain quad incident I have all too clear a memory of!) I've heard of trialers with the gearbox bolted directly to the rear axle via a UJ and making the engine & box pivot on a pair of mounts! Si Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 18, 2005 Share Posted December 18, 2005 I've heard of trialers with the gearbox bolted directly to the rear axle via a UJ and making the engine & box pivot on a pair of mounts! [Homer] Mmmmm..... unspruuuung weight. [/Homer] Quote Link to comment Share on other sites More sharing options...
Guest weeble Posted December 18, 2005 Share Posted December 18, 2005 Y ? Quote Link to comment Share on other sites More sharing options...
simonr Posted December 19, 2005 Share Posted December 19, 2005 [Homer] Mmmmm..... unspruuuung weight. [/Homer] I guess that in trialing (going slowly) - it makes little odds. How about hydrostatic drive? 4 flail mower motors and a variable displacement pump from a dust-cart should make it go! Then you can put the engine anywhere you want - even in a trailer! Si Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted December 19, 2005 Share Posted December 19, 2005 You could forget the back prop and just have front wheel drive. Quote Link to comment Share on other sites More sharing options...
