Clocking a turbo
bishbosh
Having installed my 200TDi auto B) into the 90 I have ended up with the turbo induction outlet hard up against the inner wing. :(
So, having read a bit about "clocking" the turbo, and digesting Les' thread in the tech archive, I clamped it to the bench, compressed the monster circlip (much easier said than done with my circlip pliers!) and rotated the housing. It was actually quite easy once I had the circlip under control!
Of course, solving one problem nearly always creates another - I now need to drill and tap the housing to re-mount the waste gate actuator wotsit. that's going to be tricky as it is still attached to the rest of the turbo!! :lol:
So I was going to make a bracket up instead that uses the original blind holes. Any one see a problem with that?
Also, is the rod between the vacuum actuator and the flap valve meant to act as a turnbuckle? I am assuming it does, but the rod on mine doesn't want to turn and I am worried about tearing the rubber diaphragm. Any clues?
If anyone has a handy step by step phot guide to all this, that would be great! :lol::lol:
Thanks,
the rod isn't a turnbuckle, you have to disconnect the end fitting/clevis pin undo the locknut & adjust the end fitting. the attached info should help.
for the wastegate mounting, you could make up a extended curved plate to fit the original holes.
I made up a brackety thing for my turbo wastegate, its much easier to just hold it shut with a bungee chord though :ph34r:
And can i also say that as i was cleaning a 90 fueltank the other day i noticed the the filler hose is exactly the right shape to come out of the turbo and allow a straight peice of pipe to connect to a 90 degree elbow in to the intercooler. I'm not sure about the ID etc but i can have a looksee with some verynears if its any help?
Will.
Robotman - did you manage to drill and tap it whilst still attached to the turbo? I can't get my circlip undone and don't think I can get a cler shot at it with it still attached. Also, did you drill blind holes or go right through?
I separated the turbo and then clamped the housing onto a pillar drill, hole was drilled to depth (use the depth gauge lock off!) and then tapped as BBC says using at the end a plug tap. As I recall it was M6. I acheived exactly the same depth of thread as the originals, so I'm quietly confident.
If you are unfamiliar with using taps I would suggest an Aluminium alloy turbocharger casting may not be the best place to start, have a bit practice first lol.
You can completely remove the alloy casing, so rotate it, mark the hole positions, then remove the circlip and remove the housing. There's a thin O-ring in there as well, so be careful not to damage it. The holes can then be drilled and tapped (they are M6 coarse thread).
Les.
Correction - you can Uncle Les, but 'ickle 'ol me with my collection of circlip pliers - (5 of them, count them!) can't control the damn thing enough to get it off.
I think I will go with making a new bracket. Much more my style of engineering!
