Defender - knocking sound in steering column
I recently had to drive on some very corrugated roads and have since noticed a knocking sound from the steering wheel - this occurs only at low speeds (<20km/h) and particularly when on unpaved roads, when the 'knock' can be felt (some resistance in the steering wheel)
Any ideas?
The other thing to check is that the clamps that hold the UJs on to the steering shafts are tight, I had this and it took me friggin ages to find it, eventually found one of the clamp bolts loose which wouldn't have been fun if it had come right out :huh:
  • 6 months later...
Any ideas?
Hi,
I have the same problem, but at all speeds.
I checked the CV joints and it looks ok. Can it be the upper steering column thats making this problem?
Check the front radius arm chassis bushes, get someone to shake the steering wheel from side to side while you have a good look at all the steering joints and bushes to see if anything's moving.
Check the drop arm is tight on the bottom of the steering box !!!
Hi,
I checked the UJ's again, and it was not ok. Can I change only this items or do I need to change it as a hole "COLLAPSABLE STEERING SHAFT DEF " (Part: QLG100000).
remove the bolts & nuts, slide the joint up to disengage the shaft then slide the other way to get UJ off the shaft, fitting new UJ is the reverse process.
align the bolt holes in UJ with the groove in each end of the shafts & make sure the nuts are done up tight.
:rolleyes: Wish I could arrange for an inaugural ceromony throning Ralph as king-o-part-numbers and Les Technical commentator- When they pop up, it is end of case!!! :unsure: Errm but with all respect there are numerous GURUS here..... :blush:
