bishbosh Posted September 25, 2008 Share Posted September 25, 2008 Need a bit of help please. The horn on the 90 does not work. With 12v direct from the battery it is fine, but it doesn't work form the stalk on the steering column. What colour wires should I be checking? Thanks, Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 25, 2008 Share Posted September 25, 2008 Purple. Or maybe purple with a black trace. Have I just beaten Ralph and Jamie Quote Link to comment Share on other sites More sharing options...
Guest weeble Posted September 25, 2008 Share Posted September 25, 2008 Purple. Or maybe purple with a black trace.Have I just beaten Ralph and Jamie Was that a guess Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 25, 2008 Author Share Posted September 25, 2008 Hmmm, Walfy post bang on the noggin............ Amazingly, the wire at the horn is purple with a tracer so a gold star to you (you can put it with the other ones circling your head at the moment!!) So is it purple all the way to the switch? Is there no fuse or relay in the circuit? Quote Link to comment Share on other sites More sharing options...
JST Posted September 25, 2008 Share Posted September 25, 2008 whats the matter, still thinking now Mark........ why the delay? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 25, 2008 Share Posted September 25, 2008 He's had to go and have a bit of a sleep after all that thinking James Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 25, 2008 Share Posted September 25, 2008 The horn on the 90 does not work. Perhaps it's coming out in sympathy Bish Les Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 25, 2008 Share Posted September 25, 2008 You all underestimate me. I know a lot more than you give me credit for. I only act the fool to make you lot like me Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 25, 2008 Share Posted September 25, 2008 Thanks to a google of BS-AU7a standard: Purple/Brown Horn fuse to horn relay when horn is fused separately Purple/Yellow Horn to horn relay Purple/Black Horn to horn relay to horn push I'm fairly sure it's purple/black all the way, at least it is on Defender & Series column switches. Quote Link to comment Share on other sites More sharing options...
western Posted September 25, 2008 Share Posted September 25, 2008 Hmmm, Walfy post bang on the noggin............ Amazingly, the wire at the horn is purple with a tracer so a gold star to you (you can put it with the other ones circling your head at the moment!!) So is it purple all the way to the switch? Is there no fuse or relay in the circuit? Yes purple to switch & horn & there is a fuse for the horn & other permanent 12v supplied circuits, check the horn earth wire is in place & has a good connection to horn & bonnet slam panel, if it & fuse is OK, the horn is probably dead. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 25, 2008 Share Posted September 25, 2008 You all underestimate me. I know a lot more than you give me credit for. I only act the fool to make you lot like me Who told you that someone liked you, Walfy ? Bloody people, spreading malicious rumours like that ... Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 25, 2008 Share Posted September 25, 2008 Trust Ralph to spoil a perfectly smutty thread Les Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 26, 2008 Share Posted September 26, 2008 Bish, you are not STILL rebuilding that truck are you? Chris Quote Link to comment Share on other sites More sharing options...
western Posted September 26, 2008 Share Posted September 26, 2008 Trust Ralph to spoil a perfectly smutty thread Les OI Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 26, 2008 Share Posted September 26, 2008 You all underestimate me. I know a lot more than you give me credit for. I only act the fool to make you lot like me Blimey...... You should be up for a Grammy...your so convincing Bish... Taking your time ain't you Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 26, 2008 Share Posted September 26, 2008 Thank you all for the vote of support Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2008 Author Share Posted September 28, 2008 Nice to see so many moderators take the tone of this thread down My dilemma continues - the horn unit is fine. It works - most of my neighbourhood can vouch for that . I cannot get 12V at the switch at all. The other functions of the switch work fine except the horn and flashing the headlights (side, dipped and main beam all work though). I traced the purple with black trace back to the bulkhead, but cannot see a purple with black going into the fuses. Several purples, but none with a black tracer . All the fuses are fine. At least, all the fuses I have found are fine! Are there any other fuses other than the collection in the centre of the bulkhead? Also, the interior light does not work. The light itself is fine, but I am not getting 12V to the switch. Is it possible that all three are fused together and I have not found the fuse? Help! Bluddy electrikery is killing me!! Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 28, 2008 Share Posted September 28, 2008 Bish, This any use ? http://www.indigoprime.com/landrover/Defen...g%20Diagram.pdf Complete wiring diagram for a 2002 Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 28, 2008 Share Posted September 28, 2008 300 Tdi wiring Diagram..... http://www.indigoprime.com/landrover/Defen...g%20Diagram.pdf Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2008 Author Share Posted September 28, 2008 Thanks Les, but mine's a 1989 TD!! I don't think 2002 is going to shed much light unfortunately.... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2008 Author Share Posted September 28, 2008 Hmmm, Just downloaded a circuit diagram from the tech archive and it would appear that the clock is also linked to the horn switch. Any grown ups care to look and tell me if I might be on to something? For what it is worth, the clock doesn't work either!! Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 28, 2008 Share Posted September 28, 2008 Silly question I am sure, but you have checked the fuse Bish? Chris Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2008 Author Share Posted September 28, 2008 All the fuses are fine. Silly question I am sure, but you have checked the fuse Bish?Chris QED . That is, I've checked all the fuses I have found...... Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 28, 2008 Share Posted September 28, 2008 Have you got 12 volts-ish at the feed side of the stalk switch ?, if not... bridge a wire from the out going side of the fuse to the feed side of the stalk swich to bypass that part of the loom, and see if it works then, or if you now have power to the clock ? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 28, 2008 Author Share Posted September 28, 2008 OK, two questions if I may.... Which fuse as I cannot ID where the wire comes in from the horn, and whereabouts on the switch is the feed side? Did I mention I am an electrikery numpty....? Quote Link to comment Share on other sites More sharing options...
