muddy Posted December 4, 2008 Share Posted December 4, 2008 Evening all. My newly aquired 300 disco has the coreplug behind the turbo missing, i put a new one in but after 5mins of running and excessive revving it popped out I dont think it was seated properly, well i hope so So any tips on getting it in and seated properly preferably without taking half the engine in bits would be cool. Cheers, Will. Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2008 Share Posted December 4, 2008 only best way is to remove the manifolds to gain best access. Quote Link to comment Share on other sites More sharing options...
muddy Posted December 4, 2008 Author Share Posted December 4, 2008 <expletive> Cheers ralph Do the masses put anything round them to help them seal or do they go in bare so to speak? Will. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 5, 2008 Share Posted December 5, 2008 I use threadlock/torqueseal on them, then a socket that fits snugly inside the cup to drive them in. Les. Quote Link to comment Share on other sites More sharing options...
OilIT Posted December 5, 2008 Share Posted December 5, 2008 I use threadlock/torqueseal on them, then a socket that fits snugly inside the cup to drive them in.Les. or i have used red hermatite Quote Link to comment Share on other sites More sharing options...
steve_d Posted December 5, 2008 Share Posted December 5, 2008 When you fitted the first one did the lip of the plug go in till it was flush with the block (or slightly below flush)? If not then there is reason for it to come out. If you did then you may have problems getting another to stay in place. You will need to use a new one and it may be worth a few minutes spent measuring and selecting the largest one you have available. For those with a rusted and inaccessible plug I have the following bodge. Get a flap wheel or wire brush in a flexi extension and clean up the area as best you can followed by a rag full of solvent to degrease. Then cover the whole area with body filler. The last one I did (on an XJ6) was still there 6 years later when the car went for scrap. Steve Quote Link to comment Share on other sites More sharing options...
muddy Posted December 6, 2008 Author Share Posted December 6, 2008 Well what a palava that was! After dropping the manifolds even with a socket and extension onto the core plug i couldnt swing the hammer so ended up putting a length of re-bar through the iner wing onto the socket extension Seems to have stayed in so far Quote Link to comment Share on other sites More sharing options...
Stu2985 Posted December 7, 2008 Share Posted December 7, 2008 Well what a palava that was!After dropping the manifolds even with a socket and extension onto the core plug i couldnt swing the hammer so ended up putting a length of re-bar through the iner wing onto the socket extension Seems to have stayed in so far If it is the plug on the exhaust manifold in front of the turbo I had the same issues with the plug popping out - tried all the above but kept popping out - my car runs very rich after allisport chip and intercooler. Was told possibly my exhaust getting too hot. The plug once fitted has 3 little cut outs around the manifold hole where it sits. It helps to tap the edge of the plug into these 3 small cuts with a small chisel. Despite this it kept popping out in the end i had mine welded in and had a bigger exhaust and stay off the loud pedal - so far since welding its the only way it has stayed in. Quote Link to comment Share on other sites More sharing options...
simonr Posted December 8, 2008 Share Posted December 8, 2008 I too had this issue - and came up with quite a good solution, although it does require a lathe and a press to make! Make two washers, about 5mm too big diameter to fit in the core plug hole, with an 8mm hole in the middle. Using a steel ball, press the two washers to form dishes (a bit like a small wok). Weld an M8 bolt to one of the washers (making sure the weld is waterproof) with the threaded portion sticking out of the hollow side of the dish. Then use the other washer to form a sandwich in the shape of a 'flying saucer' - with the end of the thread sticking out of the top washer. In a lathe, turn down the rim of the saucer such that it just fits in the hole in the block. hold the end of the thread with mole grips and tighten a nut, pulling the two dishes flat. This causes the circumference to expand and jam in the hole. It worked brilliantly and I was able to fit it without removing anything. Si 2 Quote Link to comment Share on other sites More sharing options...
muddy Posted December 8, 2008 Author Share Posted December 8, 2008 Thanks for the idea simon although i think i did the job quicker than it would have taken me to do all that machine work Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 11, 2022 Share Posted August 11, 2022 On 12/8/2008 at 10:04 AM, simonr said: I too had this issue - and came up with quite a good solution, although it does require a lathe and a press to make! Make two washers, about 5mm too big diameter to fit in the core plug hole, with an 8mm hole in the middle. Using a steel ball, press the two washers to form dishes (a bit like a small wok). Weld an M8 bolt to one of the washers (making sure the weld is waterproof) with the threaded portion sticking out of the hollow side of the dish. Then use the other washer to form a sandwich in the shape of a 'flying saucer' - with the end of the thread sticking out of the top washer. In a lathe, turn down the rim of the saucer such that it just fits in the hole in the block. hold the end of the thread with mole grips and tighten a nut, pulling the two dishes flat. This causes the circumference to expand and jam in the hole. It worked brilliantly and I was able to fit it without removing anything. Si I love that Si ! 😯 Mo 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 11, 2022 Share Posted August 11, 2022 Sadly, 13 years on, you can buy a pack of four using the same principle for £12: https://www.ebay.co.uk/itm/195179916346?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=EgGS6wAyTp-&sssrc=2349624&ssuid=AFY_9vavSse&var=&widget_ver=artemis&media=MORE 1 Quote Link to comment Share on other sites More sharing options...
simonr Posted August 12, 2022 Share Posted August 12, 2022 10 hours ago, Bowie69 said: Sadly, 13 years on, you can buy a pack of four using the same principle for £12: I don't think there's any 'sadly' about it 🙂 Rubber bungs is a great idea! Being able to buy them off the shelf, better still. 1 Quote Link to comment Share on other sites More sharing options...
