jimmy_neutron Posted March 23, 2009 Share Posted March 23, 2009 My battery won't see out another winter so i'm thinking that i better get sorted soon and whilst i'm at it i'm looking at fitting 2 batterys and a split charge. Obviously my first place to look was x-eng. Like the batterys in the split charge kit, but thought the relay looked a bit small for 180A rating so did some research and found this .. http://www.smartgauge.co.uk/more_relay.html I'm not wanting a slagging match, just don't want a fire in the battery box when pulling from both batterys (engine running). Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 23, 2009 Share Posted March 23, 2009 Try reading through this link. There's a mine of information there. http://www.landroveraddict.com/smf/index.php?topic=374001.0 I use a Lucas split charge relay rated at 70 amps. Not had a problem with that. mike Quote Link to comment Share on other sites More sharing options...
M&S Posted March 23, 2009 Share Posted March 23, 2009 Mike has given a very good link for reading. After that I purchased a set-up from Raw Components. I can highly recommend them as the kit is very good, comes with EVERYTHING needed. I went for the voltage sensing relay (rated at 100A) in the end as I run a TD5 and didn't fancy tapping in to any of the wiring. Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted March 23, 2009 Share Posted March 23, 2009 From memory, the X-Eng ones are quite similar to the R200R ones on here. They are rated at 200amps, meaning that you would have to pull around 400 amps to go over the rating. I'm absolutely sure that they will take short term loads much higher than that - it is usually a heat dissipation issue, so unless you are using an electric winch for logging work, I really don't see a problem. If I were you, I would contact the X-eng people and ask them what their kit is rated to. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 23, 2009 Share Posted March 23, 2009 From memory, the X-Eng ones are quite similar to the R200R ones on here. They are rated at 200amps, meaning that you would have to pull around 400 amps to go over the rating. I'm absolutely sure that they will take short term loads much higher than that - it is usually a heat dissipation issue, so unless you are using an electric winch for logging work, I really don't see a problem. If I were you, I would contact the X-eng people and ask them what their kit is rated to. x2. Forum discount from Simon at X-Eng too!! Quote Link to comment Share on other sites More sharing options...
jacks906 Posted March 24, 2009 Share Posted March 24, 2009 i have x eng battery kit top notch not had any probs altho if you did want something a little more heavy duty devon do a heavy duty on off solinoid looks good bit of kit dave Quote Link to comment Share on other sites More sharing options...
simonr Posted March 25, 2009 Share Posted March 25, 2009 I agree that there is a lot of mis and dis-information kicking around on ratings of relays. The relays are sold to us as having a 180A rating - but as said in the advert - is this a continuous rating? A 10 minute or even 10 second rating? I tested one of the relays by using it to short out a yellow top optima which was delivering about 900A. It took 20 sec for the relay casing to melt. Remarkably, once it had cooled down - it still worked (but was a fairly unusual shape). Using the same battery (recharged) and an improvised resistor to limit the current to 200A I repeated the experiment with a new relay. It got quite warm - but after 10 mins was still intact and working. At that point the battery was going flat and the current dropped below 200A so the test was terminated. These relays are made in Italy. I tried the same test on a much cheaper version from China - and it was rubbish. At 900A it turned to liquid within 10 seconds and stopped working. At 200A it just stopped working after 2 minutes. A few people have complained that the relays are not continuously rated at 180A, however, I am satisfied that they are up to the job - and back that up with a 5 year unconditional warranty. Si Quote Link to comment Share on other sites More sharing options...
headhunter Posted March 25, 2009 Share Posted March 25, 2009 I have a VSR fitted Voltage Sensitive Relay http://www.power-store.com/view-item.asp?i...amp;id=196& These will work in emergency parallel mode at 1250amps for 10 minutes! Also allows for charging via solar panel. More expensive but belt and braces. They also do an excellent cut off switch giving Battery 1, Battery 2, Both and Off settings, that can be padlocked Off for security. Voltage: 12, 24, 32 & 48V DC Continuous Rating: 400A Intermittant Rating: 525A Cranking Rating: 1500A Terminal size: 3/8" (10mm) http://www.power-store.com/view-item.asp?i...amp;id=191& Designed for marine market but very suitable for Land Rovers. Matthew on here is an expert in these products and can source them for you. John Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted March 25, 2009 Author Share Posted March 25, 2009 5 year unconditional warranty.. Thats an impressive offer B) Quote Link to comment Share on other sites More sharing options...
jacks906 Posted March 25, 2009 Share Posted March 25, 2009 this was the other sort i was on about slightly heavier duty http://www.devon4x4.com/products_a/p2c127/.../-isolator.html dave Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2009 Share Posted March 25, 2009 on my 110-- 100amp Marrelli alternator, 2 x Odysessy PC1700 batterires both charged through the standard LR split charge relay & upgraded wiring as required, no problems with the charge not getting to the batteries. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 25, 2009 Share Posted March 25, 2009 this was the other sort i was on about slightly heavier dutyhttp://www.devon4x4.com/products_a/p2c127/.../-isolator.html dave I have two of these as my winch isolators. Excellent piece of kit. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted March 25, 2009 Share Posted March 25, 2009 x2. Forum discount from Simon at X-Eng too!! How do you get that then? Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2009 Share Posted March 25, 2009 How do you get that then? bottom of his reply above & look at his signature line where it says 'click here' Quote Link to comment Share on other sites More sharing options...
