SteveG Posted May 10, 2006 Share Posted May 10, 2006 I bought a TD5 90 tank Guard off ebay, got it for 25 quid, and it arrived today.. As soon as I opened it up I thought the holes looked too big, and after holding it up to tank they were.. The holes are all in the right place, but are too big for existing bolts.. If I simply use existing bolts with washers it will move. So what's the best way to fit this??? Cheers Steve Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2006 Share Posted May 10, 2006 Large diameter 'penny' washers under the boltheads would be the easiest & quickest, do them up tight, don't think it'll move/fall off. or find some washers of the correct bolt diameter & weld them into the oversize holes to bring them to the correct size. Quote Link to comment Share on other sites More sharing options...
white90 Posted May 10, 2006 Share Posted May 10, 2006 cut some tube that fits inside the holes on the gaurd to act as a boss then the bolts with washers that cover the hole diameter. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 10, 2006 Share Posted May 10, 2006 You are lucky then, mine is very like that and the holes are big to cover "Land Rover build tolerances" - and mine still didn't line up! Mind you that may be something to do with the fact I twatted the tank cradle doing a three point turn in a stone run on top of the highest mountain round these parts Quote Link to comment Share on other sites More sharing options...
freeagent Posted May 10, 2006 Share Posted May 10, 2006 get some stainless penny washers, the clamping force will stop the guard moving. m@tt. Quote Link to comment Share on other sites More sharing options...
simonr Posted May 10, 2006 Share Posted May 10, 2006 Friction is your friend! Just crack the bolts up with a washer & it will be fine! Si Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 10, 2006 Author Share Posted May 10, 2006 washers it is then, thanks I should have picked some up today as I'll have to wait until after weekend now. Cheers Steve Quote Link to comment Share on other sites More sharing options...
headhunter Posted May 11, 2006 Share Posted May 11, 2006 washers it is then, thanksI should have picked some up today as I'll have to wait until after weekend now. Cheers Steve Steve I don't know where you go for washers/bolts etc. but Glenwood Bolts & Screws 01223 892095 at the Grip Trading Estate Hadstock Rd Linton carry a stock of stainless bolts washers nuts etc. They may not have large plate washers but if you give them a ring they will try to help, They are not expensive and will take £ notes for small orders. Another option is DJ Evans in St. Botolph's Lane, Bury St. Edmunds, 01284 754132, the owner Richard is a mate and they carry a comprehensive stock do deliver and have a large hand & power tools selection as well. John Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 11, 2006 Share Posted May 11, 2006 I've used DJ Evans quite a bit, helpful folks they are too. Quote Link to comment Share on other sites More sharing options...
freeagent Posted May 11, 2006 Share Posted May 11, 2006 you could always try screwfix, next day delivery and you'll probably find a pack of 100 is just as cheap as 20 from elsewhere... you have to spend a bit to get free postage though...... .........just a thought. Quote Link to comment Share on other sites More sharing options...
simonr Posted May 13, 2006 Share Posted May 13, 2006 Do you have a hole-saw? They, as well as being good for making holes, make nice washers from the material you are cutting holes in! Si Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 13, 2006 Author Share Posted May 13, 2006 Cheers guys and John for the suggestion of a couple of places - good to know in future. I normally use Powerdrive Systems in Haverhill. It just looks like a shed next to MM Leisure, but is an aladin's cave of tools and fastners. I've only ever gone in their once and they haven't had what I wanted. That was propshaft bolts which according to them are a bit unusual so can't blame for not having them. All fitted today, did need some lining up stephen to get all bolts off but was easy using a trolley jack. Just need to get some sumo bars now and some other things too Cheers Steve Quote Link to comment Share on other sites More sharing options...
