Ghost14 Posted May 18, 2010 Share Posted May 18, 2010 I am currently running a 1.2 transfer box and am new to this malarky so please excuse my ignorance. I've heard you can change the low ratio in a transfer box without altering the high ratio? my reason for this is I have an auto box and it is carp at engine breaking going down steep inclines. is this possible? what do you need? and how do you do it? cheers Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 18, 2010 Share Posted May 18, 2010 er "No" LT230 TBoxs come in various Ratios - ALL Ratios affect High Range, low is the same on ALL of them at 3.321. To change Low Range you have to change the CWPs, which also change hiugh at the same time Nige Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 18, 2010 Share Posted May 18, 2010 Get an Ashcroft Underdrive...does the job...not cheap tho ! But worth it for comps' ! Quote Link to comment Share on other sites More sharing options...
Ghost14 Posted May 18, 2010 Author Share Posted May 18, 2010 oh, i thought you could change the gears inside the transfer box.. Quote Link to comment Share on other sites More sharing options...
martinspragg Posted May 19, 2010 Share Posted May 19, 2010 My Defender came with a military transmission which has a lower 1st gear than the standard issue trans. I subsequently had to replace the trans and used a civilian box for the rebuild and in all honesty the military box 1st was way too low, almost useless in most driving situations and the new civilian trans is much easier to pull away with from a standing start. Having said that I am sure if you need to pull a tank out of a ditch then that low 1st gear is useful but you have to weight up the pros and cons of such a set up for us civvies. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 19, 2010 Share Posted May 19, 2010 I am currently running a 1.2 transfer box and am new to this malarky so please excuse my ignorance. I've heard you can change the low ratio in a transfer box without altering the high ratio? my reason for this is I have an auto box and it is carp at engine breaking going down steep inclines. is this possible? what do you need? and how do you do it? cheers Sorry if I'm teaching granny to suck eggs , but from my experience of driving an auto offroad there is neglible difference in engine braking. Are you locking it in 1st? Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 19, 2010 Share Posted May 19, 2010 Sorry if I'm teaching granny to suck eggs , but from my experience of driving an auto offroad there is neglible difference in engine braking. Are you locking it in 1st? Unfortunate Ross there is quite a difference......... The typical RR ZF4HP22 auto box ratios are, 1st 2.48 2nd 1.48 3rd 1.00 4th 0.73 Where as the typical R380 manual box ratios are; 1st 3.60 2nd 2.11 3rd 1.40 4th 1.00 5th 0.77 So 1st in an auto is like 2nd (plus a bit) in a manual ............... With a diesel it is not so bad…………… but with a petrol you really know the difference Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 19, 2010 Share Posted May 19, 2010 oh well auto i've driven is petrol... and the manual is diesel and the auto was on 33" and the manual on 205's... Quote Link to comment Share on other sites More sharing options...
Ghost14 Posted May 19, 2010 Author Share Posted May 19, 2010 so what are my options?? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 19, 2010 Share Posted May 19, 2010 Change diff ratios or use a Borg Warner t-box and the Tomcat low ratio chain and cog set, think they lowered it by about 30%. Or, just put up with it as it is, and learn to use the brakes.... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 19, 2010 Share Posted May 19, 2010 Maxi-Drive make lower low ratio kits. 30% and 49% lower (4.3:1 and 5:1). Quote Link to comment Share on other sites More sharing options...
Ghost14 Posted May 19, 2010 Author Share Posted May 19, 2010 is that for the diff? ideal i'd like to keep my high ratio and just change the low. would the tomcat stuff fit in my current tbox? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 19, 2010 Share Posted May 19, 2010 The Maxi drive stuff is just for low range I believe. The Tomcat stuff will only fit in the Borgwarner transfer boxes. not the LT230 ones. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 19, 2010 Share Posted May 19, 2010 Maxi-Drive make lower low ratio kits.  30% and 49% lower (4.3:1 and 5:1). Seems not any more... http://forums.lr4x4.com/index.php?showtopic=20265 You won't be able to change just the low box unfortunately, but then with bigger tyres you will want to drop the high as well, 1.2 on 35" tyres is going to play havoc with your fuel economy.... and make driving it on the road a very tiresome experience, with autobox changes all over the place. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 19, 2010 Share Posted May 19, 2010 Seems not any more... http://forums.lr4x4.com/index.php?showtopic=20265 That part of the business was purchased by MR Automotive in Brisbane. They still manufacture the low range gear kits. PLus or minus half the cost of an underdrive. Quote Link to comment Share on other sites More sharing options...
Ghost14 Posted May 19, 2010 Author Share Posted May 19, 2010 Seems not any more... http://forums.lr4x4.com/index.php?showtopic=20265 You won't be able to change just the low box unfortunately, but then with bigger tyres you will want to drop the high as well, 1.2 on 35" tyres is going to play havoc with your fuel economy.... and make driving it on the road a very tiresome experience, with autobox changes all over the place. am keeping my current tyres for the mo, have loads of other things to do first, was kind of jumping a gun a bit. so you can get an underdrive thing which will change my low but not my high? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 19, 2010 Share Posted May 19, 2010 these gear sets change the low ratio in the transfer box. The underdrive is like an overdrive but works in the opposite way in lowering the gearing. like an overdrive it is selectable, so no it wouldnt affect your high range when its disengaged. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 19, 2010 Share Posted May 19, 2010 am keeping my current tyres for the mo, have loads of other things to do first, was kind of jumping a gun a bit. so you can get an underdrive thing which will change my low but not my high? OK. To clarify... There are 3 possible routes. 1) Maxidrive low range gears. This changes your low ratio only. 30% or 49% lower. 4.3:1 or 5:1 instead of 3.3:1. 2) Fit an Ashcroft underdrive. When engaged, it added 2.69 times the current gearing. Thus 2.59*3.32= 8.9:1 low/low range. You then have 4 possible transfer case ratios. 1.4:1, 3.3:1, 3.7:1 and 8.9:1. 3) Fit lower range differential gears AND higher high range gears. If you change to 1.2 transfer gears and 4.1 diff gears, high range will be around the same and low range is 16% lower. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 19, 2010 Share Posted May 19, 2010 Graham - just use the brakes! it is not against the rules to brake going down hill - just learn to cadence brake and you will be fine. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 20, 2010 Share Posted May 20, 2010 I was curious about the Maxidrive gears, wanted to confirm they were still available, as I heard they were not, however: Peter,Thanks for your enquiry. Yes we are producing the rockcrawlergears. They cost A$2000 for a 30% reductionor A$2200 for 49% reduction. This includes the cost of a newintermediate gear. Quote Link to comment Share on other sites More sharing options...
