henry Posted September 29, 2010 Share Posted September 29, 2010 Last Night on the way home I completely lost drive, so I coasted to the side of the road and had a fiddle with the gears and Hi/Lo. The only combination that worked was to put the land rover into low ratio with diff lock on. I then limped home trying not to allow the rear wheels to spin to much. Is this definitely a case of a broken transfer box? I was recommended when I purchased the car at the beginning of the month that the transfer box should be replaced. If it is I need to source a new box very soon. I live in Portsmouth, and would greatly appreciate if any body knows the whereabouts of a replacement box that is close. The land rover is a 1993 200TDi 110 I hope my tale is not to vague for someone to help me diagnose the fault. Many Thanks Henry Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 29, 2010 Share Posted September 29, 2010 Will it drive in high box D/Locked ? If so diff CV or Shafts ? Nige Quote Link to comment Share on other sites More sharing options...
henry Posted September 29, 2010 Author Share Posted September 29, 2010 Just been to the car and it does move in High range with Diff lock on aswell as low range. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 29, 2010 Share Posted September 29, 2010 broken front or rear half shaft then, possibly diif, most likley Transfer box is OK Nige Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 That means you've broken a diff/shaft/CV. First off, take it out of diff lock and drive forward and back to ensure it disengages, then chock the wheels, apply the FOOT brake, select first gear and gently let the clutch up. Then get someone have a look underneath to see which propshaft is spinning. The spinning prop is the prop going to the broken axle, so you can investigate further once you know which end is away. Quote Link to comment Share on other sites More sharing options...
crwoody Posted September 29, 2010 Share Posted September 29, 2010 Sounds like you need to try it in gear with the difflock off and take a look to see if either of the propshafts are spinning, try it with the handbrake on first though - you don't want to get run over by your own car - it's not very nice. ( don't ask me how I know ) Edit; beaten to it Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 Probably better using the foot brake, given the handbrake acts on one of the propshafts, and if it was a faulty rear axle, applying the handbrake could allow the transfer case to transmit drive to the front end negating what your trying to achieve Quote Link to comment Share on other sites More sharing options...
henry Posted September 29, 2010 Author Share Posted September 29, 2010 So it is not my assumed transfer box crisis. We have just been to investigate and the front prop is spinning. What is going to be the best order look at the next possibilities? Quote Link to comment Share on other sites More sharing options...
Tibout Posted September 29, 2010 Share Posted September 29, 2010 I'll check the cv's and shaft first as they will come out together you'll know once you take it apart if it's neither the cv or half shaft on both side then diff will have to come out. Thierry Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 ok, stick the transfer box into neutral and jack up one of the front corners and spin the wheel, then do the same on the other side. Its really just down to "feel" as to try and tell which side is broken or not. I'd imagine the side with less resistance is probably the broken one. After that your onto stripping the hubs down to get the various components out to see whats broken. Quote Link to comment Share on other sites More sharing options...
henry Posted September 29, 2010 Author Share Posted September 29, 2010 Been out again to identify the problem. I put transfer box into neutral then jacked up right side and span the wheel. The front prop shaft started to spin, but then completely stopped. I then did exactly the same on the left side. The Prop shaft started to spin, more positively until I tried to change the direction. The prop then would not spin at all, forwards or reverse. Next I put the transfer box into gear so as to lock the prop shaft. I jacked up both sides to see if the movement of one wheel would go through the diff to the other wheel, but this did not work. I strongly suspect that this may be a diff problem, would you agree? Quote Link to comment Share on other sites More sharing options...
steve b Posted September 29, 2010 Share Posted September 29, 2010 Drain the diff oil to see if there are any bits,if there are bits it'll be the diff planet gears and/or the cross pin . If you remove the level plug you should be able to see (with a very small torch) what moves when the jacked up wheel is rotated, if you rotate 1/2 turn one way then sharply 1/2turn the other way you should be able to feel the 'drag' thru the cv and half shaft. My 2p is on a blown cv cheers Steveb Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 Yep you're going to need to strip it down. Easiest thing to do is remove the caliper, and hub assy, then unbolt the stub axle from the swivel housing, and draw the shaft out. You'll soon find out which side is broken! Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Share Posted September 29, 2010 This is excellent info. Now i know what happens when you break a shaft, diff or CV.... or flange Thanks All. Duely stored in my head for my trip........ Quote Link to comment Share on other sites More sharing options...
JST Posted September 29, 2010 Share Posted September 29, 2010 sounds like the diff if both wheels being rotated made the prop turn a bit initially. you would of probably heard a diff going though, certainly driving on it afterwards! Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 30, 2010 Share Posted September 30, 2010 If its a busted CV the bits inside might catch/jam enough to turn the prop a bit? Quote Link to comment Share on other sites More sharing options...
