landy V8 Posted December 7, 2010 Share Posted December 7, 2010 Hi Trying to decide on next vehicle,i just know it's going to be a 110 CSW either 200 or 300tdi.What are the pro/cons of either vehicle. Also the truck will have full cage/2"lift/winch/35" tyres Thanks for any advice Ralph Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 7, 2010 Share Posted December 7, 2010 Basically no difference engine performance wise. The 300Tdi is supposed to be slightly more refined but every one I've been in still sounds like a tractor. Apparently, the 300Tdis are slightly less fuel efficient, although I doubt it would make any difference in the real world. More important are the other differences in the vehicle. The 300Tdi will have the better (stronger and "smoother") R380 gearbox, as well as Disc brakes all-around. It will also have 24-spline half-shafts and diffs but still the weak 32-spline CVs. Fitting alloy wheels is much easier on 300Tdi models due to the smaller drive members and lack of brake drums. 300Tdis have much better electrics too, using proper looms and plugs rather than the awful older Lucas style systems. Either vehicle will be at least 12 years old so rusting issues will be present wherever you look, although obviously any 200Tdi is going to be older. No difference really regarding your planned mods, although you don't see many 110 CSWs with the "full complement". Probably because they cost so much more than other types of Land Rover. Quote Link to comment Share on other sites More sharing options...
landy V8 Posted December 7, 2010 Author Share Posted December 7, 2010 Basically no difference engine performance wise. The 300Tdi is supposed to be slightly more refined but every one I've been in still sounds like a tractor. Apparently, the 300Tdis are slightly less fuel efficient, although I doubt it would make any difference in the real world. More important are the other differences in the vehicle. The 300Tdi will have the better (stronger and "smoother") R380 gearbox, as well as Disc brakes all-around. It will also have 24-spline half-shafts and diffs but still the weak 32-spline CVs. Fitting alloy wheels is much easier on 300Tdi models due to the smaller drive members and lack of brake drums. 300Tdis have much better electrics too, using proper looms and plugs rather than the awful older Lucas style systems. Either vehicle will be at least 12 years old so rusting issues will be present wherever you look, although obviously any 200Tdi is going to be older. No difference really regarding your planned mods, although you don't see many 110 CSWs with the "full complement". Probably because they cost so much more than other types of Land Rover. for the sake of 24 spline axles/r380/loom there doesn't seem alot in it.i can always upgrade these mechanicals if needed.i definately know of rust issue's after rebuilding my 90 so will be after the best i can get. Thanks for the info Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted December 7, 2010 Share Posted December 7, 2010 300 tdi would be my choice. serpentine belt over multi belt on the 200. also 200 tdi cylinder heads aren't made anymore so parts easier and in many cases cheaper for the 300. Steve Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 7, 2010 Share Posted December 7, 2010 if it helps, I was considering the same thing when I was on the lookout for my truck. In the end the decision was made for me because I found my Defender and she was a goodun and it didn't matter a trott whether she was a 200 or 300. It was love at first sight, ahhhh Quote Link to comment Share on other sites More sharing options...
western Posted December 7, 2010 Share Posted December 7, 2010 if I was buying my 1st 110, it would be a 300tdi, the 200's are getting scarce in great condition & cylinder heads are becoming difficult to obtain with no alternative available, although the 200 seems to be the stronger engine. Hi Ralph Welcome to LR4x4.com & I'm not talking to myself,as it's my name too, that should confuse everybody else Quote Link to comment Share on other sites More sharing options...
landy V8 Posted December 7, 2010 Author Share Posted December 7, 2010 Hi Ralph Yeh i know,it's nearly confused a few people on here before. The only thing is trying to find a decent 300tdi 110 within my budget(£3-4k).Which then will leave me about £3-4k to spend when i sell my V8 90. Don't want to go anywhere near a dealer but even finding one on fleabay is getting difficult. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 7, 2010 Share Posted December 7, 2010 7 cylinder heads are becoming difficult to obtain with no alternative available Surely 1 cylinder head is enough Ralph ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 7, 2010 Share Posted December 7, 2010 (edited) Surely 1 cylinder head is enough Ralph ? Mo that should have been & cylinder heads --- amemded now Edited December 7, 2010 by western Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 7, 2010 Share Posted December 7, 2010 that should have been & ctlinder heads --- amemded now ctlinder? amemded? have you been drinking western? Quote Link to comment Share on other sites More sharing options...
western Posted December 7, 2010 Share Posted December 7, 2010 no, wish I had then I would have an excuse, my one finger typing & generally tired. right spell checked this time Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 8, 2010 Share Posted December 8, 2010 Also changing cam belts on the 200tdi is a menace of a job. And it is definitely worth getting the R380 - the LT77 is one of the worst gearboxes ever foisted on the public. Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 8, 2010 Share Posted December 8, 2010 I have a 200tdi on a R380 shorty gearbox, lovely setup now, but with foresight I would have gone with a 300tdi they are now as common as 200's where 5 years ago, lots of cheap spares and engines available. Quote Link to comment Share on other sites More sharing options...
