Mean Green Posted June 24, 2006 Share Posted June 24, 2006 I have just changed the bulkhead on my 200tdi 90 for a TD5 version. And I have came up against a snag. A couple of years back I doubled up the washer jets on the old bulkhead and therefore had 4 water jets, two on each side rather than a single twin in the middle. However, the wiper arm holes are different on the new bulkhead and the jets are not a good fit. Is there a way round this? Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2006 Share Posted June 24, 2006 Try a rubber washer on each side of the location to tighten it up a bit, Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted June 24, 2006 Share Posted June 24, 2006 If you do a lot of off road I found the best mod you can do to the washers is throw away the jets, Fit a T piece and then find a pair of spray bars from a peugeot 405 (local scrap yard). A couple of cable ties and they fit perfect along the wiper blade's, Get the water right where you want it and loads of it. Its the first mod I will do to any landrover I own in future! Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 25, 2006 Share Posted June 25, 2006 Greg, slightly OT but can you give some details on the swap, how easy and was the TD5 bulkhead complete or bare? ONy my 200 one is showing early signs of age and swap for a fresher bulkhead might make more sense than patxhing it. TIA Quote Link to comment Share on other sites More sharing options...
Mean Green Posted June 25, 2006 Author Share Posted June 25, 2006 Greg, slightly OT but can you give some details on the swap, how easy and was the TD5 bulkhead complete or bare? ONy my 200 one is showing early signs of age and swap for a fresher bulkhead might make more sense than patxhing it.TIA Hi Trev, My bulkhead was a brand new bare item, and I would say the job is about what you would expect it to be, as the bulkhead is a fairly major part of the structure of the vehicle .. time consuming rather than difficult. As for the differences between Tdi and TD5, there are a fw minor changes, but nothing that cant be "fixed". The biggest pain that I had was refitting the heater and steering arm... there were holes in the bulkhead to take the items but it took ages to track down the correct rivnuts to fit the holes. I had the engine out of mine and have been doing other bits and pieces while it was off, but you should be able to do it with the engine in place. If you want to do the job quickly then a complete bulkhead might be the easier way to go, but if you want to do it all ... and are willing to become very friendly with yout LR parts dept, then a bare bulkhead is fairly straighforward to do. Quote Link to comment Share on other sites More sharing options...
pigster Posted June 26, 2006 Share Posted June 26, 2006 can I see a pic of this please... sounds like a good idea... If you do a lot of off road I found the best mod you can do to the washers is throw away the jets, Fit a T piece and then find a pair of spray bars from a peugeot 405 (local scrap yard). A couple of cable ties and they fit perfect along the wiper blade's, Get the water right where you want it and loads of it. Its the first mod I will do to any landrover I own in future! Quote Link to comment Share on other sites More sharing options...
Mark90 Posted June 26, 2006 Share Posted June 26, 2006 Pug washer mod Quote Link to comment Share on other sites More sharing options...
reedx Posted June 26, 2006 Share Posted June 26, 2006 can I see a pic of this please... wiper mod Quote Link to comment Share on other sites More sharing options...
pigster Posted June 26, 2006 Share Posted June 26, 2006 tar muchly wiper mod Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted June 26, 2006 Share Posted June 26, 2006 Im upset now, Thought that was an original idea I had! Turns out others had already done it. I must admit every time I get a clod of mud on the screen its 100 time's easier to wash off than with those two poor jets of water that you have as standard! Quote Link to comment Share on other sites More sharing options...
western Posted June 26, 2006 Share Posted June 26, 2006 (edited) A neat solution, I've removed the single twin jet from the centre of the bulkhead & fitted a pair in front of each wiper arm, works well for me Edited June 26, 2006 by western Quote Link to comment Share on other sites More sharing options...
simonb Posted June 27, 2006 Share Posted June 27, 2006 Yer did the same to mine, but then I have 3 wiper arms on the front as well Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 27, 2006 Share Posted June 27, 2006 If you want to do the job quickly then a complete bulkhead might be the easier way to go, but if you want to do it all ... and are willing to become very friendly with yout LR parts dept, then a bare bulkhead is fairly straighforward to do. Thanks for that, reassuring. Sought of guessed it might be a lot of work and wouldn't want to find I'd got the wrong bulkhead halfway through. Though lie you say s/h complete unit in better nick would be a simpler answer. Quote Link to comment Share on other sites More sharing options...
