L835 Posted January 21, 2011 Share Posted January 21, 2011 Sorry if this has been covered before, but I need to fit a second, under seat fuel tank in my 110 CSW. Will a series tank fit? I have a scrap 90 with a good tank, which would fit,but being a CSW the filler would exit through the 2nd row door! Thanks in advance! Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2011 Share Posted January 21, 2011 have a look at page 524 onwards for 110SW twin fuel tank parts Quote Link to comment Share on other sites More sharing options...
L835 Posted January 21, 2011 Author Share Posted January 21, 2011 Thanks! certainly looks like a series tank.... Quote Link to comment Share on other sites More sharing options...
rrover Posted January 25, 2011 Share Posted January 25, 2011 Or try this: http://www.safari-equip.co.uk/index.php?page=75 Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2011 Share Posted January 25, 2011 if you need to see how the under wing tank fits I can e.mail the fitting info. Quote Link to comment Share on other sites More sharing options...
reads90 Posted January 25, 2011 Share Posted January 25, 2011 I have two tanks on my 110. The rear is standard but the front is a 70 Ltr as seen below But you could just put a 90 one under the drivers seat of the 110 and then have a v8 fuel pump to pump from the front tank to the rear. If you get a series tank you could just fill it up by lifting up the drivers seat BTW. Here is my 110 and you can just see the tank under the drivers side Quote Link to comment Share on other sites More sharing options...
LiamC Posted January 26, 2011 Share Posted January 26, 2011 I don't think a 90 tank will go under the seat of a 110 CSW as the second row floor gets in the way. I am in the process of fitting a second tank to my 110 as part of my veg oil system. I was going to fit a military fuel tank from a series/lightweight that fills from under the seat base as I too had no where to put an external filler cap. In the end as I didn't need a very big tank I have gone for a 22L plastic marine type tank under the drivers seat instead. Quote Link to comment Share on other sites More sharing options...
farmerboy_y2k Posted January 30, 2011 Share Posted January 30, 2011 have a look at page 524 onwards for 110SW twin fuel tank parts What all the camel 110's are fitted with. Quote Link to comment Share on other sites More sharing options...
jeremy996 Posted January 30, 2011 Share Posted January 30, 2011 I had this same problem and hoped that the LR Defender parts would do the job. No one appears to have them and there are none in the dealer network. I have a Series military underseat tank which was bought as new old stock from Bearmach; I have no idea if they have any more and we have a few fitting issues, so it is lower than intended and backwards. My installation I cannot show images here as my site encodes them as HTML Quote Link to comment Share on other sites More sharing options...
tacr2man Posted January 30, 2011 Share Posted January 30, 2011 You can use a series top fill military tank , the standard series tank will fit in a HT or truck cab , but not astation wagon as no where for filler (2nd row door) . You have to make a bracket (very simple) angle iron and weld to chassis to support front the rear IIRC uses single bolt with rubbers to isolate. simplest(ie most reliable) is use pump to pump to rear tank, when fuel level in rear tamk is low enough to hold all contents of front tank . This does not require a front tank fuel guage , as you know what you put in and it wont change till you pump out. It also overcomes fuel return problem , and also air leak chance is lowered due to not having switch over taps . I use this system on my 110 , but its petrol V8 same principles apply . HTSH Quote Link to comment Share on other sites More sharing options...
