DEANO3528 Posted August 7, 2005 Share Posted August 7, 2005 Tried this one on several boards but never received much input. Is there a cheaper alternative to LR sunroof seals? Sure I read somewhere that Pug are the same, but checking my glass against the roof on my boys 106 shows a marked difference in size (pug is larger). Comments please as I really like things to work when they are fitted rather than being permanently siliconed over. TIA Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted August 7, 2005 Share Posted August 7, 2005 You aren't going mad I remember seeing that about Pug seals...I am afraid I don't remember where though... Sorry Will Quote Link to comment Share on other sites More sharing options...
onions Posted August 7, 2005 Share Posted August 7, 2005 I definitely read that it was the 106 sunroof seal. Let me know how you get on because I can't continue pulling the boot floor soundproofing up every month to give it time to dry out. I was thinking of replacing the rear sunroof seal with the pug one instead of the 2 litres of silicone grease which are currently doing the job. Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2005 Share Posted August 7, 2005 (edited) Deano, I've a unused seal here, for a 90/110/Defender glass sunroof, if it's any use PM or e.mail your postal address Edited August 7, 2005 by western Quote Link to comment Share on other sites More sharing options...
GregK Posted August 7, 2005 Share Posted August 7, 2005 I too heard that pug seal fits. What you might be able to do is to fit a wire all the way round between sunroof seal and frame. This will lift the rubber up, making it tighter fit to the glass. Other way to make it more water tight is to clean the rubber and glass then apply some talcum powder to rubber. Talcum powder [or the stuff you get in bicycle puncture repair kit] will prevent rubber to stick to glass and damaging it further [never tried this one but it supposed to work] Greg. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 8, 2005 Share Posted August 8, 2005 I too heard that pug seal fits. What you might be able to do is to fit a wire all the way round between sunroof seal and frame. This will lift the rubber up, making it tighter fit to the glass. Other way to make it more water tight is to clean the rubber and glass then apply some talcum powder to rubber. Talcum powder [or the stuff you get in bicycle puncture repair kit] will prevent rubber to stick to glass and damaging it further [never tried this one but it supposed to work] Greg. french chalk is the stuff in puncture repair kits IIRC Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted August 8, 2005 Author Share Posted August 8, 2005 Yes Tony it is french chalk. Nice offer Western, I'll be in touch shortly. It seems that the glass is a different profile to the roof, meaning that it's high in the centre and low at the edges. That can't help things as it compresses the corners below roof level and leaves the centre proud. Also the plasticky mechanism doesn't seem to want to tighten as well as an overcentre mechanism might. Tried a bit of reconditioning with vaseline but I think it would only work on a new item. I have used string or rope in the past to help a seal work, but there isn't any way of keeping it in place in this case. Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2005 Share Posted August 8, 2005 Nice offer Western, I'll be in touch shortly just been out and measured my glass panel it's 151/4 inches or 387mm front to rear and 291/4 inches or 744mm side to side, hope that helps give you some idea of the seal size Quote Link to comment Share on other sites More sharing options...
TJ101 Posted August 8, 2005 Share Posted August 8, 2005 The workshop managed to seal one up ok, using the wire method,,(as above),, that was a while ago, and he has not complained of a leak since Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 8, 2005 Share Posted August 8, 2005 Gents, I know a man who knows.... I'm sure he said it was Pug seals but you had to chop a chunk out as it is a tad big. I'll pop in and see him tomorrow. Quote Link to comment Share on other sites More sharing options...
GregK Posted August 8, 2005 Share Posted August 8, 2005 I have used string or rope in the past to help a seal work, but there isn't any way of keeping it in place in this case. Could you not glue the string in few places with evostick? I know sunroof seal has very small lip but glueing it in might just help to keep it there. french chalk is the stuff in puncture repair kits IIRC Thanks for name info. Greg Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 9, 2005 Share Posted August 9, 2005 I promised I'd speak to Titch today and didn't get a chance as it went a bit "Pete Tong" at work today.... Will try to do it tomorrow, sorry. Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted August 10, 2005 Author Share Posted August 10, 2005 Thanks all, you're very helpful. Cutting a chunk out would work if it's the same profile seal. Could try glue, but it'll take some cleaning up now as everything is covered in vaseline! Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 14, 2005 Share Posted August 14, 2005 Peugeot seals are the same as it is exactly the same sunroof. "....but why bother when the land rover ones are now only nine quid....." Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted August 22, 2005 Author Share Posted August 22, 2005 Sorry all, been busy doing stuff for our club newsletter and forgot all about this line of enquiry. £9 seems a lot cheaper than was quoted on the old post where pug seals were first mentioned. Sorry too, to Western for not sorting out the offer of a seal. It would seem that the seal will be too big as my panels are only 14¼" back to front. At 9 quid I think I might as well buy a pair of new ones. Again thanks for the offer. I'll have to check how to fit them, I think White90 posted instructions a while back. Cheers all. Quote Link to comment Share on other sites More sharing options...
richard1978 Posted December 30, 2010 Share Posted December 30, 2010 remove the roof lining, undo the sandwhich plates on the sunroof make sure you remove all traces of the old seals then sikaflex ( marine grade polyurathane ) the sunroof fairly liberally. place back on roof, re-tighten the sandwhich plate on the sunroof then with tissue and wd40 or similar, remove the squished out sikaflex so it does not dry on you paint work. you will never have to do the job again, ever... you will need a silicon gun for the job too, and i said liberally, but you dont need that much to do both sun roof seals, one tube will easily be enough. and you can use the rest sealing anything else you might fancy on the landy. richard Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted December 30, 2010 Share Posted December 30, 2010 Richard, I'm sure Deano would have appreciated your help - however I'm not even sure he still has the vehicle as he posted that question back in 2005... No worries though - welcome to the forum. Matt Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 30, 2010 Share Posted December 30, 2010 Holy thread revivals Batman! Quote Link to comment Share on other sites More sharing options...
richard1978 Posted January 3, 2011 Share Posted January 3, 2011 wow, did not even look at the dates, sorry. (and why would he not have it still)??? happy new year to all on here. and sorry for being blind/stupid/both. Quote Link to comment Share on other sites More sharing options...
