steve_d Posted May 18, 2011 Share Posted May 18, 2011 We have ARB lockers on a contest vehicle and lost front drive during an event last Sunday. Having pulled the drive shafts, which were considered to be the culprits at the time, they are in good order. When I stripped the diff down I found that the diff casing has sheared from its flange which bolts to the crown wheel. Has anyone seen or heard of this before? Many thanks Steve Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 18, 2011 Share Posted May 18, 2011 We have ARB lockers on a contest vehicle and lost front drive during an event last Sunday. Having pulled the drive shafts, which were considered to be the culprits at the time, they are in good order. When I stripped the diff down I found that the diff casing has sheared from its flange which bolts to the crown wheel. Has anyone seen or heard of this before? Many thanks Steve yep several, its a weak point of them, you can buy a new flange Nige Quote Link to comment Share on other sites More sharing options...
zim Posted May 19, 2011 Share Posted May 19, 2011 Team Gunit broke there's like this a couple weeks ago...oops G Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 19, 2011 Share Posted May 19, 2011 One issue (Steve ex KAM Diffs) belives this to be is build quality, in very hard competition use bolts / holes are not either clean enough, or old bolts used that are more easily streched further, and or incorrect locking compound used / porrly torqued up and / or a combination of all. We have had difs in recently where the bolts were just finger tight, sure they were not when they were originally built, but these had all loosened, owner was a tad stunned when they undid so easily, loose bolts or streched bolts here means the flange can "Shunt" backwards and forwards, a sign of this startuing is the "Holes" become "Ovals", then it not too far if continued for the flange to just give up and shear They are only a casting, and not too thicker one at that, so there is not much meat if things get loose they can be bought new from ARB but they are defo "Not Cheap" Hope this helps Nige Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 19, 2011 Author Share Posted May 19, 2011 Have now decided to bin it and replace with Ashcrofts own version. 'Steps back and waits to be told that is also a bad move' Although their reputation would leave me to think it's the best move. Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 19, 2011 Share Posted May 19, 2011 Have now decided to bin it and replace with Ashcrofts own version. 'Steps back and waits to be told that is also a bad move' Although their reputation would leave me to think it's the best move. Steve Certainly a damned sight cheaper than an ARB! Quote Link to comment Share on other sites More sharing options...
Mr Ian Posted May 19, 2011 Share Posted May 19, 2011 Hi Unfortunately we have seen this before on ARB which is why we use billet steel for the main body on our locker. Our Lockers were given a good testing at the recent Croatia event by a number of competitors including the winner Jim (Gigglepin) Marsden. Regards Ian Ashcroft Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 19, 2011 Share Posted May 19, 2011 Have now decided to bin it and replace with Ashcrofts own version. 'Steps back and waits to be told that is also a bad move' Although their reputation would leave me to think it's the best move. Steve <vulture Mode On> Steve Could you PM what you wHat for the bitsa arb parts Might be useful for me <vulture Mode off> Nige Quote Link to comment Share on other sites More sharing options...
reads90 Posted May 19, 2011 Share Posted May 19, 2011 We have ARB lockers on a contest vehicle and lost front drive during an event last Sunday. Having pulled the drive shafts, which were considered to be the culprits at the time, they are in good order. When I stripped the diff down I found that the diff casing has sheared from its flange which bolts to the crown wheel. Has anyone seen or heard of this before? Many thanks Steve Yeah did it twice in my winch challenge 90 about 6 years ago when I had a Kam 4.75 crown wheel Quote Link to comment Share on other sites More sharing options...
western Posted May 19, 2011 Share Posted May 19, 2011 <vulture Mode On> Steve Could you PM what you wHat for the bitsa arb parts Might be useful for me <vulture Mode off> Nige just for Nige Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 19, 2011 Author Share Posted May 19, 2011 <vulture Mode On> Steve Could you PM what you wHat for the bitsa arb parts Might be useful for me <vulture Mode off> Nige Hi Nige With the high probability our driver will break the one at the other end I think I need to hang on to the bits. However if he breaks that one in the same way I will bear you in mind because by that time his wallet will have taken quite a beating. The diff was at the end of the day and followed a roll into a Scotish Burn, An attack on a gate post which destroyed the N/S front wing, lights and bonnet corner. Another incident removed the O/S front wheel spat but he dosen't know when and where. Steve Quote Link to comment Share on other sites More sharing options...
the real muddy90 Posted May 19, 2011 Share Posted May 19, 2011 Welcome to the club If When mine break again I will also be giving Mr Ashcroft a bell. Note to self, must drive faster & win said item on certain events. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 19, 2011 Share Posted May 19, 2011 Re the ashcroft Locker, I have absolutely nothing but good over it, spec, build quality and price, a winning combo, if my ARBs ever (RD56s so I stand a chance) end up causing me to think of something else I would defo try and buy a Ashcroft locker over anything else on the market. Nige Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 20, 2011 Author Share Posted May 20, 2011 Hi Unfortunately we have seen this before on ARB which is why we use billet steel for the main body on our locker. Our Lockers were given a good testing at the recent Croatia event by a number of competitors including the winner Jim (Gigglepin) Marsden. Regards Ian Ashcroft Hi Ian when I called to order one of yours they were out of stock but someone went away and had a dig around under a bench somewhere and found one for me. Should be arriving today with luck. Thanks Steve Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 20, 2011 Share Posted May 20, 2011 Pics , thoughts views and install would be useful thread for the forum ? Nige Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 20, 2011 Share Posted May 20, 2011 Don't think you'll be disapponted, Sevice is second to none IMHO Mine - 3.5 HD Ring an pinons and pegged Built as a front and rear specific Full build here - My build up Regards Les Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 21, 2011 Author Share Posted May 21, 2011 Right Ashcroft locker has arrived and very pretty it looks too. Now the problems start. 1. When an ARB locker is installed one of the domed locking/adjuster rings is replaced with the ARB version. As I didn't fit the ARB I don't have the old ring in 'That box' under the bench. Anyone know a part number and where I can get one? Second hand would do. 2. What preload torque are the main roller bearings set too? 3. What backlash should I see as a starting point for setting the CW/Pinion mesh? 4. Anywhere I can find a table of the bolt torque figures? Nige is right this is missing from the tech archieve but as can be seen from my questions I'm not the one to write it. Thanks for any help Steve I only know the axles to be Disco 2. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 21, 2011 Share Posted May 21, 2011 I have loads of the bits you need Pm me ady I'll bung one in the post (FOC), or your welcome to pop up ? Nige Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 27, 2011 Author Share Posted May 27, 2011 Thank you Nige and Steve for the diff build today. Proved just how little I know about the task. Hopefully your introduction to the Ashcroft locker was worthwhile. It certainly looks a nice piece of kit. Thanks Steve Quote Link to comment Share on other sites More sharing options...
Mark Posted May 27, 2011 Share Posted May 27, 2011 I hope their 'competition' diffs last better than their 'competition' shafts and CV's.... I am afraid, however, It's not on my shopping list certainly. Mark Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted May 28, 2011 Share Posted May 28, 2011 Thank you Nige and Steve for the diff build today. Proved just how little I know about the task. Hopefully your introduction to the Ashcroft locker was worthwhile. It certainly looks a nice piece of kit. Thanks Steve Your welcome, It was a pleasure to meet you. The Ashcroft locker does look to be a good improvement over the ARB, it was nice to set up and everything fitted as it should. Ps, that Ford Focus RS orange looks fantastic on your 110" Regards, Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 28, 2011 Share Posted May 28, 2011 I have an ARB here that came out of Mo-Murphys busted diff. The same thing had happened to that. Les. Quote Link to comment Share on other sites More sharing options...
Escape Posted June 16, 2011 Share Posted June 16, 2011 Just took my P38a with Ashcroft lockers for a 4000km testdrive to Ladoga Trophy, plenty of opportunities to use them and very pleased with the performance! Quote Link to comment Share on other sites More sharing options...
