Orgasmic Farmer Posted September 8, 2011 Share Posted September 8, 2011 http://www.landyrebuild.com/rust-removal.shtml Quote Link to comment Share on other sites More sharing options...
Darren Roberts Posted September 8, 2011 Share Posted September 8, 2011 Yes, but with water softener salt.... Quote Link to comment Share on other sites More sharing options...
renault4 Posted September 8, 2011 Share Posted September 8, 2011 yes I've tried this and it works a treat,I've done lots of small parts and I am looking for a larger container to do my springs, no hard work required just a bit of patience and a quick scrub with a scotch pad and then it's ready to paint. Quote Link to comment Share on other sites More sharing options...
Night Train Posted September 8, 2011 Share Posted September 8, 2011 For a larger container stack some light weight building blocks on the drive or patio to form the walls of a container big and deep enough to take the component. Lay in a sheet of damp droof membrane and then fill with water and salts. I don't think it would do a chassis though unless the blocks are mortared in place first. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted September 8, 2011 Author Share Posted September 8, 2011 Got loads of caustic soda here so may give it a try. What setting on the battery charger should I use.... higher the better? Quote Link to comment Share on other sites More sharing options...
renault4 Posted September 8, 2011 Share Posted September 8, 2011 don't use caustic soda, (very dangerous stuff) washing soda, 89p. per bag from asda safe to use and non-toxic. I've only got one setting on my charger (6 amp) and it works fine. Quote Link to comment Share on other sites More sharing options...
renault4 Posted September 8, 2011 Share Posted September 8, 2011 For a larger container stack some light weight building blocks on the drive or patio to form the walls of a container big and deep enough to take the component. Lay in a sheet of damp droof membrane and then fill with water and salts. I don't think it would do a chassis though unless the blocks are mortared in place first. what an effing good idea. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 9, 2011 Share Posted September 9, 2011 Yeh, I like that. I'd only got as far as Jenolite in a jam jar. It's good, and no salt residue, but wallet wise its definately a jam jar operation Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 9, 2011 Share Posted September 9, 2011 Got loads of caustic soda here so may give it a try. What setting on the battery charger should I use.... higher the better? The more current you get through it the faster it works, you can increase the current flow to some extent by adding more sacrificial electrode surface area. It works very well, but be patient. You'll be amazed at the carp that ends up in the tank after cleaning something. When it's done a quick rub with a scotchbrite pad to remove the black (don't let it dry on it as it's a bitch to clean off otherwise) then get paint on it asap I first tried it after reading about this guy refurbishing his pillar drill http://www.ablett.jp/workshop/drill_press.htm about half way down the page you'll see his attempt at it with a few comments on current. Anyway bit of baking soda and some electric and watch the magic happen .... oh and try not to explode! Quote Link to comment Share on other sites More sharing options...
disco_al Posted September 9, 2011 Share Posted September 9, 2011 For a larger container stack some light weight building blocks on the drive or patio to form the walls of a container big and deep enough to take the component. Lay in a sheet of damp droof membrane and then fill with water and salts.I don't think it would do a chassis though unless the blocks are mortared in place first. i reckon it would. you would only need to be two blocks high to fit the chassis in there. alternatively, what about one of those cheap kids paddling pools? lay the chassis on top, then inflate the pool around it? Quote Link to comment Share on other sites More sharing options...
disco_al Posted September 9, 2011 Share Posted September 9, 2011 grrr - darn forum upgrades.....try item number 230668351663 on ebay (won't let me post a link) would get all the steel items done in one go on that one :) Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 9, 2011 Share Posted September 9, 2011 Not quite a Land Rover chassis but the Sunken Side Car of Doom is a good example. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted September 9, 2011 Share Posted September 9, 2011 I was a bit worried for the dog there Quote Link to comment Share on other sites More sharing options...
My name is Mud Posted September 9, 2011 Share Posted September 9, 2011 Perhaps an easier way is to use citric acid. A 5% mixture will get rid of rust in about a day, no need for electricity. Available cheap anywhere where they sell farm supplies. Here's what I know about it: 1. Make a 5% solution into say, a bucket. I just use my eyes for measurement, still works. 2. Use a wire brush or something to get rid of loose rust. 3. Throw parts into solution. No need for gloves, you could even drink it. Bubbles will start to form on rust. 4. The warmer the solution, the faster it works. Room temperature is fine, next to radiator even better. Mixing it up every once in a while also helps. 5. Once it's done, you can see black pitting where rust used to live. Just rinse parts with water, dry and apply primer. The parts will go brown fast if you don't paint or dip in oil or something. Put a lid on your container if you want to reuse the solution, otherwise it will develop mold. Or just flush it down the drain. Quote Link to comment Share on other sites More sharing options...
hanlon Posted September 9, 2011 Share Posted September 9, 2011 does any one know if this would work on corroded brake callipers thanks Quote Link to comment Share on other sites More sharing options...
Night Train Posted September 9, 2011 Share Posted September 9, 2011 what an effing good idea. Not quite a Land Rover chassis but the Sunken Side Car of Doom is a good example. This is why you should use a damp proof membrane, doesn't leak like the blue tarpaulin does. Quote Link to comment Share on other sites More sharing options...
