welling4x4 Posted September 22, 2011 Share Posted September 22, 2011 I am going to fit a bigger intercooler on my 200 tdi & need to put more pipe work to make it fit. Will this mean a loss of pressure to the turbo or will I be able to compensate it by adjusting the waste gate a touch.????? Any help would be greatfully received . Andy Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 22, 2011 Share Posted September 22, 2011 No loss in pressure, but marginally more lag due to greater volume in intercooler and pipework. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted September 22, 2011 Share Posted September 22, 2011 You will probably find that it will increase lag a bit. Adjusting the waste gate won't help in this respect as that just determins how much boost it holds. Your issue is what happens before it gets to boost pressure. A big intercooler is great for mid to high end performance but a direct replacement/same sized one that is more efficient at cooling would be better for low end power improvements. Steve Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 22, 2011 Share Posted September 22, 2011 hmmm, so obviously needs for each driver are slightly different, if i bought a mid sized intercooler, would that improve top end a little, (dont need top end too often but sometimes is used) but it would also help with the lower end, (obviously slightly more lag) and for towing and the likes? its just made me wander wether to go full sized or not, id rather have as little lag as possible to be honest, but also want a bit of higher end brum. Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted September 22, 2011 Author Share Posted September 22, 2011 So what's the way to sort out the lag issue ?? This seems to be a right pain in the arse now. All I wanted was a bit more ufm . @ top & bottom end can't this been done please ????? Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted September 23, 2011 Share Posted September 23, 2011 not without buying a VNT kit. Tbh though as someone who has tuned a Tdi and fitted a VNT I will say it's never going to be a rocket ship, and to get more out you have to put more in - if that makes sense! Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 23, 2011 Share Posted September 23, 2011 Will one of these help, http://www.ebay.co.uk/itm/TURBO-MANUAL-BOOST-CONTROLLER-NOT-BLEED-VALVE-/220537042109?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item33590834bd by decreasing waste gate creep? I've been considering fitting one, but dont know how much difference it'd make. Quote Link to comment Share on other sites More sharing options...
crowmann Posted September 23, 2011 Share Posted September 23, 2011 I fitted a huge intercooler and was worried about delay and loss of pressure across the cooler - if there was any I could not tell even vaguely. What I did do though was take the pressure feed pipe to the IP and wastegate off the manifold rather than the stock location of the turbo itself. Seems to come up to pressure 0.8bar exactly like it did with the stock cooler on. The advantage being it reads manifold pressure which is exactly what the engine recieves. I recommend the upgrade see other recent intercooler thread for ebay type units. Essential bits cost me about £225 and a bit of pleasant tinkering. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted September 23, 2011 Share Posted September 23, 2011 The question's not so much about the intercooler size as creating non standard extra pipework. It is this that will cause more lag as a larger void needs to be filled before it gets to the bigger intercooler, this is why turbo pipes usually get replaced with silicone, it stretches less under pressure and thus reduces lag. I would say go with a larger one, you certainly won't be worse off at bottom end but will see improvements mid-high. A vnt will help further still along with the correct fueling mods. Steve Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 26, 2011 Share Posted September 26, 2011 my idea was to reroute the wastegate to the manifold but leave the I/P on the turbo housing. this should give fuelling as if it was higher pressure but the wastegate would think it is lower pressure, = pressure comes on slightly earlier, but better fuelling, obviously as my engine is rather turned up, the fuelling thing may be pointless but am definately going to to the turbo thingy Quote Link to comment Share on other sites More sharing options...
landy V8 Posted September 28, 2011 Share Posted September 28, 2011 can i ask what may be a s daft question,but what is the "IP" you are talking about. Quote Link to comment Share on other sites More sharing options...
Lars L Posted September 29, 2011 Share Posted September 29, 2011 Injection Pump. I.e. the pipe that goes to the diaphragm on the pump which increase fuelling according to turbo boost pressure. Quote Link to comment Share on other sites More sharing options...
