sas pinkie Posted October 29, 2011 Share Posted October 29, 2011 I am currenlty trying to get the heated front windscreen in my wolf working. At the moment the fuse for the screen (fuse number 19) keeps blowing. Its a 15 A fuse. unplug the screen and the fuse doenst blow. I have checked the main supply cable to the screen, and it doesnt have any shorts to ground. Any other thoughts? I havent measured the impedance yet, but could some one measure thiers so I have somthing to compare it too.... Its a two terminal, Td5 type screen. with the supply on the drivers side and the earth on the passengers side. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 29, 2011 Share Posted October 29, 2011 (edited) Isn't the fuse supposed to be a 30 amp for a TD5 heated screen? Edit: Just checked the circuit diagram and it shows 30amp for the screen on the 2002MY Edited October 29, 2011 by CwazyWabbit Quote Link to comment Share on other sites More sharing options...
western Posted October 29, 2011 Share Posted October 29, 2011 in the loom I've got here it has a 30amp fuse between the brown 12v feed connection 7 the brown/orange trace connection to the screen, it's this loom I have http://defender110.nightmail.ru/Extracts/Heated%20Windscreen.pdf not yet fitted to my 110. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 29, 2011 Share Posted October 29, 2011 Ralph, that link is broken. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 29, 2011 Share Posted October 29, 2011 http://defender110.n...0Windscreen.pdf Strange works for me. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 29, 2011 Share Posted October 29, 2011 oh, i just get this: http://qip.ru/error/404 Quote Link to comment Share on other sites More sharing options...
western Posted October 29, 2011 Share Posted October 29, 2011 checked it & it works for me OK. http://defender110.nightmail.ru/Extracts/Heated%20Windscreen.pdf Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 29, 2011 Share Posted October 29, 2011 Darn Russians and their inconsistent web servers Here's the HFS wiring for 2002-on Defenders: Quote Link to comment Share on other sites More sharing options...
chris200100 Posted October 30, 2011 Share Posted October 30, 2011 Sorry to step in on this post but could you wire a front screen to wiring for the rear screen if your disconnect the rear one as the rear one on mine the glass is knackered and was going to replace with a no heated one I got lying around in my garage.? Quote Link to comment Share on other sites More sharing options...
discomikey Posted October 30, 2011 Share Posted October 30, 2011 as long as the wiring is up to it yes Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted October 30, 2011 Share Posted October 30, 2011 The front screen uses about three times the current of the rear one, so no, I would not wire a front one direct to the rear screen wiring. However, you can use the rear screen circuit to power a relay which switches a new 30A feed for the front screen. Nick. Quote Link to comment Share on other sites More sharing options...
sas pinkie Posted October 31, 2011 Author Share Posted October 31, 2011 ok, cheers, I will upgrade the fuse, I used a 15 Amp fuse because the wolf circuit diagram and the fuse layout on the cover both say it should be 15Amp.... It wouldnt be the first mistake I have found between the military paperwork and reality. Quote Link to comment Share on other sites More sharing options...
