QD tow bars, differences in price vs quaility?
Hi all, on a laning trip last weekend, (my 3rd so far) I managed to slide down into some ruts, and though I didn't get stuck (momentum saved the day!) I noticed that I picked up a fair bit of dirt on my rear mounted plough, it seems like a standard fitment, the truck is a 1895 90" CSW,even though it dosen't stick down too far, and because I don't intend to do a huge ammount of towing I thought I might fit a QD towbar.
Question is, which one?
I realise each have theoir favourites, and many seem to like the southdown one, but seing as it's not on their website, I'm not so sure as I'd like to see what I'm buying first, the Extreme one Here: http://www.extreme4x...LE_TOWBARS.html
vs the Terrrafirma one Here: http://www.land-rove...Hitch&year=1987
there's about £30 between them, so is there any difference, in terms of strength?
does anyone do much towing with them, and how do they perform?
I'd be planning on making/adapting a dixon bate slider/drop plate to allow the tow ball to go low enough, again, wondering about strength and the torsion placed on the whole contraption....
So basically what I'm asking is: Strength? durability? Which is best?
I had a custom receiver hitch made by a specialist towbar place.
I've done very few miles towing with it and mostly with an empty trailer, but I have towed 3.5 ton down a hard surfaced but pot holed green lane.
I have noticed that it is a bit more clanking when towing and the metal around the pin has a very minor bit of wear.
Also due to the extreme drop on the tow hitch (35" inch tyres and lifted suspension) the specialist towbar place put braces from the bottom of the hitch back to the normal towbar mounts on the chassis.
I have a southdown one on my 90 and its great, but I got it second hand and I don't think they make them any longer.
I don't know about the quality of the above but I would rather my money went to Terrafirma/Allmakes than Extreeeeeeeme4x4.
I believe Guardian make one similar to the southdown one.
If you're meaning clanking around in the receiver hitch hole, then a bolt or two clamping it will stop the movement.
Well last feed back was only 3 days ago so I would say more likely they are waiting new stock to list post Christmas .... just a guess though
Also from his feedback he has been buying overalls, Oxy cutting gear, mig wire over Christmas ...... sounds like he is still in business
A friend of mine had a guardian version on his 90, it was a very well made piece of kit and I shall probably buy the same soon.
Just trying to find their website though and it seems to have disappeared :unsure:
I have one of Guardians (i'm good friends with Spencer) tank guards on my 110, the prototype infact.. it works and fits like a dream.
Spencers wife is currently in hospital being very unwell, however, his number is: 07977995686 if you ring him, i'm sure he'll do the best he can given the current situation hes in.
Apologies, that will teach me to jump to conclusions! All the best to Spencer's wife, I'll wait a few weeks before I give him a ring.
VB is there any chance you could stick a few photos up? Particularly how it mounts to the crossmember/chassis rails? Sadly my friend has now sold his 90 so I can't go and look at it.
Harry
Thanks VB!
On a different note, what is the legality with towing with this set-up i.e. does it need some kind of approval?
Mine's a 1989 90 if it makes any difference.
Harry
Only vehicles build after 1st August 1998 need a type approved towbar, so you should be ok.
