stuck Posted February 10, 2012 Share Posted February 10, 2012 Gent's, I'm aiming to convert the viscous fan on my 4.6 110 to twin electric fans tomorrow & could do with knowing the correct quantity of antifreeze. When I put the engine in I put 5 Ltrs of the pink stuff in, is this about right? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted February 10, 2012 Share Posted February 10, 2012 find out the total capacity of the cooling system, i dont know it off hand sorry 66% of the cooling system needs to be water, so obviously the other 34% needs to be antifreeze!!! Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted February 10, 2012 Share Posted February 10, 2012 66% of the cooling system needs to be water, so obviously the other 34% needs to be antifreeze!!! :wacko: its 50/50 for best results. Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted February 10, 2012 Share Posted February 10, 2012 :wacko: its 50/50 for best results. depends on the temperature its going to be subjected though Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 10, 2012 Share Posted February 10, 2012 No more than 60% pink antifreeze. 5-litres in and then top up with water will be fine. Les. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 10, 2012 Share Posted February 10, 2012 And the engine... and the antifreeze type... Stuck: Presumably your 4.6 wasn't fitted to your Defender as standard, so I'd be looking at the manual for the car it came out of. Presumably a Range Rover. Quote Link to comment Share on other sites More sharing options...
stuck Posted February 10, 2012 Author Share Posted February 10, 2012 Hi James, Yes it's from a RR, unfortunately I only have a book of lies for a RRC hence the question. Quote Link to comment Share on other sites More sharing options...
Phillis Posted February 10, 2012 Share Posted February 10, 2012 Fill it up with water using a measuring jug, remember what it used then empty it, then refill it with antifreeze/water Quote Link to comment Share on other sites More sharing options...
jbs Posted February 11, 2012 Share Posted February 11, 2012 50/50 regardless Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 11, 2012 Share Posted February 11, 2012 I think most land rover cooling systems are around the 12 litre mark. Mike Quote Link to comment Share on other sites More sharing options...
DagdaNI Posted February 11, 2012 Share Posted February 11, 2012 tbh id just go the 5 litres again get it run up and test it, i wouldnt rekon youd be far off other option (as said already) is fill it totally with water while measuring amount run up to temp with heaters turned to hot check for leaks, this way you know its all good and antifreeze amount needed but as said id go lazy man option Quote Link to comment Share on other sites More sharing options...
rick Posted February 12, 2012 Share Posted February 12, 2012 Or just buy pre-mix. I buy it by the 20l drum and it works out the same price as concentrate without having to buy de-ionised water. Quote Link to comment Share on other sites More sharing options...
Spearos Posted February 13, 2012 Share Posted February 13, 2012 I pre mix my anti freeze in a 5l container, 3 parts anitfreeze and 2 parts water gives me a 60/40 mix. I then just fill up from this container knowing the antifreeze/water ratio is correct. Quote Link to comment Share on other sites More sharing options...
