Towing
Frax
A friend of mine said that is going to become illegal to tow using a strap or rope and if I was going to do so I would need to buy a Tow Pole.
Is this true and if so what tow pole would you recommend – sprung or un-sprung.
Weight rating ------- any advice welcome.
i thought it was already illegal to use tow rope, I've been using a 5ft scaffold pole with trailer type socket and a braket welded at the other end bolted through chassis so far no problem. Was thinking of buying an A frame but told they will be illegal soon
Nothing official just rumours. I tow a Disco or Defender so due to weight I do prefer the solid bar because the tow vehicle normally has broken down so little or no brakes, max towing distance is about 10 mile 6 is on motorway.
use of a towrope or strap is only illegal on dual carraigeway/motorway AFAIK,
towrope only to get the dead vehicle to 'a place of safety' for example nearest layby or safe place to park.
sprung towbars are best of at least 2 tonne minimum rating. mine is one of these
http://intertradeuk....&products_id=34
given to me by a friend who used to decommision RAC vans.
I think so, used for any road towing I get asked to do, much better than a rope, towed vehicle cannot overrun the bar or smack my 110 in the rear.
didn't buy mine I was given it or it went in the skip, the place where my friend used to work had a contract with RAC to decommision & strip out all the kit/livery & part of the contract rules was they could not sell any of the stripped out kit, all had to be scrapped but they could have a cretain amount of items, so he got me a almost new virtually unsed towbar with different end connections for the dead vehicle, the end to my 110 has a normal towball hitch but a 76mm NATO ring is available I believe.
To be honest I would not trust most if them, Ralf's one looks the most robust one I have seen but could not justify that price. I have seen quite a lot of home made efforts that look stronger than the shop jobs.
Rope/strap is illegal on motorway except when recovering to a place of safety, but there's nothing I can find about any othe roads yet. My tow pole is also a scaffold with two trailer htches, 3500Kgs mind, not the lighter ones.
As for A frames, I did a bit of studying a little while ago whilest planning for E test, and I believe there was information then indicating A frames would become illiegal. It was surrounding the fact that a vehicle on an A frame behind, say, a motorhome, was still classed as a trailer unless the vehicles brakes were modified to be operated by the towing vehicle - by an overrun on the A frame for example. I'll have to see if I can find it, it was surrounding the fact that if you don't have E entitlement, then there was in fact only 1 car on the road that was legally within the 750kgs towing limit, and it wasn't the smart car.....I'll see if I can find it again, for interests sake.
My understanding was that you could tow a vehicle on a rope to a place of safety but towing for extended distances was not looked on well (insurance companies might have something to say about it?) and wasn't allowed at all on motorways and only on dual carrageways in an emergency.
Also if towing on a rope then BOTH vehicles had to be taxed, MOT,d and insured.
Using a bar meant the towed vehicle became a trailer so didn't neccasarily need to be road legal except as a trailer since it could be braked by the towing vehicle, not to sure where you ended up with regard to towing weights etc.
As said the issue I have heard about A frames was about towed weights, un braked trailers etc. The vehicle on the A frame needed some sort of link so it became a braked trailer, I believe these are possible and available via the motor home market. Also some of the big motor homes are based on commercial vehicles and pretty heavy in there own right so maybe allowed to tow a small car un braked
how come you can drive your vehicle to a mot garage without mot and tax as long as it is booked in
Because that is the way the law stands...Be aware that VOSA/ DVLA/ DoT have no means of identifying a vehicle on or coming back from an MOT so you will still get your demand for VED if the camera catches you.....
Personally I prefer a rope/strap and being on the back. That way I can control both my vehicle and brake for the tow cat.
If you need to recover a vehicle without brakes. Use that to tow as the towing vehicle shouldn't be using brakes.
both vehicles have comply with the above even if towed with a bar or 2 wheels of towed vehicle are on the road [garage speclift] only other way to get around no tax//insurance is dead vehicle on a car transport trailer or lorry.
that doesn't sound true, towed vehicle still requires a driver to steer/brake/indicate, so cannot be classed as a trailer.
A frames are a very grey area -- depends on towing & towed vehicle weights, hence motorhomes towing things like smart cars or similar sized cars on a A frame, not legal for a LR to use.
"If you need to recover a vehicle without brakes. Use that to tow as the towing vehicle shouldn't be using brakes." I hope you don't mean anywhere near the road........ In fact I really hope that was a joke!
If you know how to tow correctly. Most people do not, then you will know as I've already said, THE TOWING VEHICLE SHOULD NOT USE THE BRAKES AT ANY TIME. ALL BRAKING IS DONE BY THE VEHICLE ON TOW.
OR are you one odf those people on the back that lets the rope/ strap drag on the ground ?
I think the comment was more to the point that a vehicle without brakes shouldn't be on the road or frankly being driven at all unless in order to recover form offroad to a trailer or site for repair. I guess if you are in the middle of no where with two broken vehicles one with power and one with brakes then this is the way to do it but not something to be recommended in most circumstances.
Other than that you are correct.
