wettstuff Posted March 23, 2012 Share Posted March 23, 2012 Evening all chaps Driving my 300tdi 110 tonight the expansion tank decided to go bang. Now providing i can get a replacement first thing in the morning is it just a simple task of swapping over and just topping up with water/antifreeze?(if so how much of each part) Looking at the puddle that formed it didn't seem like a vast amount of water. Will there be any need to drain/bleed the system Thanks in adavance Mark PS: Does anyone in berkshire has a spare 300tdi expansion tank in exchange for some beer tokens Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2012 Share Posted March 23, 2012 this is the later version straight swap for the black version, part number PCF101590 1/3rd anti freeze to 2/3rd water will be sufficient for UK use. Quote Link to comment Share on other sites More sharing options...
wettstuff Posted March 24, 2012 Author Share Posted March 24, 2012 Cheers western many thanks Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 24, 2012 Share Posted March 24, 2012 I have a black one from a 200tdi in the garage that you can have if it us compatible with your truck. Only thing we'd need to do is pressure test it to check its definitely ok. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted March 24, 2012 Share Posted March 24, 2012 this is the later version straight swap for the black version, part number PCF101590 Does anyone know if they're better in anyway or just a different colour? I know the 300Tdi expansion tank is a weak point and can split. There are aluminium replacements available, although i'd worry that something else (radiator) might then become the weak point. Quote Link to comment Share on other sites More sharing options...
Sirocco Posted March 24, 2012 Share Posted March 24, 2012 I would like to know this to. A friend had the black one split and replaced with the above. G Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2012 Share Posted March 24, 2012 probably a different type of plastic & less prone to cracking under pressure/heat/vibration. my black one is OK [famous last words] but thinking of swapping it anyway. Quote Link to comment Share on other sites More sharing options...
reedx Posted March 24, 2012 Share Posted March 24, 2012 The new ones have the other advantage of being able to view the coolant level from the outside, that was the reason for changing mine. Colin Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted March 25, 2012 Share Posted March 25, 2012 I've got a spare 300tdi expansion tank if you want it? I am in West End near Lightwater and M3. I'll be at home from 1.00pm onwards. I'll send a pm as well. Quote Link to comment Share on other sites More sharing options...
jimyd Posted March 25, 2012 Share Posted March 25, 2012 Are you sure of the reason for the expansion tank exploding? Its probably worth checking / replacing the cap and doing a few checks for head gasket failure, hopefully its just an old duff tank, but would hate for you to put a new one on and for the same thing happen. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 25, 2012 Share Posted March 25, 2012 I threw that plastic header tank on mine away after the reports of the black ones cracking. Fitted a nice alli one from Alli-Sport with a proper rad cap as well. Quote Link to comment Share on other sites More sharing options...
wettstuff Posted March 25, 2012 Author Share Posted March 25, 2012 Jim, it didn't quite explode just a tiny tiny crack in the seem, got a new one from safari engineering in the end saturday, Seems ok so far Mark Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 26, 2012 Share Posted March 26, 2012 Jim, it didn't quite explode just a tiny tiny crack in the seem, got a new one from safari engineering in the end saturday, Seems ok so far Mark Quite normal for this to happen. Quote Link to comment Share on other sites More sharing options...
