stuck Posted May 1, 2012 Share Posted May 1, 2012 Gent's, Received my Sumo bars today (Excellent service from Mr Lewis) & I'm trying to get them on tonight. Unlike the original bars the nuts that lock the TRE into the tapers aren't castellated and the TRE's aren't drilled to accept split pins. Does anyone know the torque setting that should be used? Thanks, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2012 Share Posted May 1, 2012 are they nyloc nuts then ? if not castelated & able to be split pinned. I just do them up tight 5 white knuckles should be sufficient. LR RAVE manual says ball joints steering 40Nm Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 1, 2012 Share Posted May 1, 2012 Forgive my ignorance but wtf is a sumo bar? ....other than a drinking establishment for over-weight japanese men... Edit: ok yes found them at the bottom of the google page, below the aforementioned drinking establisments Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2012 Share Posted May 1, 2012 beefed up steering trackrod/draglink http://www.sumobars.co.uk/ Quote Link to comment Share on other sites More sharing options...
stuck Posted May 1, 2012 Author Share Posted May 1, 2012 Cheers Ralph, Yes, just Nylocks provided with the HD TRE's. Quote Link to comment Share on other sites More sharing options...
muddy Posted May 1, 2012 Share Posted May 1, 2012 PFT- pretty f*cking tight, but not FT or RFT Quote Link to comment Share on other sites More sharing options...
stuck Posted May 1, 2012 Author Share Posted May 1, 2012 PFT- pretty f*cking tight, but not FT or RFT Cheers Muddy Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 4, 2012 Share Posted May 4, 2012 PFT- pretty f*cking tight, but not FT or RFT Is that two grunts or one? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 4, 2012 Share Posted May 4, 2012 Just use the Nylocs . Mine came with nylocs I'm sure. I do them to one grunt, with the 19mm spanner Quote Link to comment Share on other sites More sharing options...
Dads Toy Posted May 4, 2012 Share Posted May 4, 2012 Just put mine on but then found the track rod protector (that bolts into the diff casing) won't fit. The gap is big enough for the bar but when it's bolted on it's too high for the bar to go in. I've left it off at the moment and aim to either get a better guard or get a large spacer made. Malcolm Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 5, 2012 Share Posted May 5, 2012 Why does everyone use nylocs? Whats wrong with a castle nut and split pin? I through the TRE nylocs away and drill a hole for a split pin on mine. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 5, 2012 Share Posted May 5, 2012 Why does everyone use nylocs? Whats wrong with a castle nut and split pin? I through the TRE nylocs away and drill a hole for a split pin on mine. I much prefer a castle nut, you can undo the bloody things again! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 5, 2012 Share Posted May 5, 2012 Because times move on. A nyloc is just as good as a castle nut and split pin, if not better as its quicker! Nothing wrong with a nyloc, and unless you've been a chimp they are no harder to undo. Quote Link to comment Share on other sites More sharing options...
