eds Posted May 3, 2012 Share Posted May 3, 2012 Just some advice on oil leaks for the mot Sorry if I identify diff pinion wrongly, it is the bit the drive shaft connects to the diff. If this weeps will it fail? In fact what is the situation with oil leaks. I heard the regulations have changed. Thank you all as usual Ed Quote Link to comment Share on other sites More sharing options...
landy V8 Posted May 3, 2012 Share Posted May 3, 2012 apparently you are not supposed to have any leaks(never gonna happen with a LR).just before you drive it in,get underneath and go round with a rag and wipe parts over. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 3, 2012 Share Posted May 3, 2012 What is defined as a leak? I know that sounds a stupid question but does it have to have a drip visible or does just a generally oily appearance constitute a leak? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 3, 2012 Share Posted May 3, 2012 Well the 88 went through hers with the usual line down the oil filter, which I never seem to be able to stop, and she passed. My garage is strict too. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 3, 2012 Share Posted May 3, 2012 If its bad, just wipe it over before it goes in. Mine has a few drips and it passed the MOT just after easter. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted May 3, 2012 Share Posted May 3, 2012 What is defined as a leak? I know that sounds a stupid question but does it have to have a drip visible or does just a generally oily appearance constitute a leak? http://forums.lr4x4.com/index.php?showtopic=16541&view=findpost&p=170104 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 3, 2012 Share Posted May 3, 2012 If that's the case then it would have to be fairly bad to fail Quote Link to comment Share on other sites More sharing options...
GBMUD Posted May 3, 2012 Share Posted May 3, 2012 On February 13th my 90 got an advisory "004 Offside front tractor joint has slight leak", by which they meant the front OS swivel seal. If your pinion seal is weeping then I would say you are fine, if there is oil everywhere then less so, and if it drips on the tester then God help you! They are quite easy to change... Chris Quote Link to comment Share on other sites More sharing options...
eds Posted May 3, 2012 Author Share Posted May 3, 2012 Thanks for the helpful advice I am hoping a wipe will get me through I should of done it when the weather was nice I am not overly confident as my engine is fairly dirty all over And I think there is a drip on the bell housing too I'll get under there and wipe away all drips and hope for the best Thanks again Ed Quote Link to comment Share on other sites More sharing options...
xorigamixartstx Posted May 7, 2012 Share Posted May 7, 2012 I thought it was just me that did things like that ;-) Ha ha apparently you are not supposed to have any leaks(never gonna happen with a LR).just before you drive it in,get underneath and go round with a rag and wipe parts over. Quote Link to comment Share on other sites More sharing options...
Steve King Posted May 8, 2012 Share Posted May 8, 2012 If it is a Salisbury dif, I have a genuine seal that you can have.... Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 8, 2012 Share Posted May 8, 2012 A diff pinion oil seal leaking, no matter how bad is not a reason for rejection. The regulations concerning oil leaks have not changed in any way. Quote Link to comment Share on other sites More sharing options...
