jagwit Posted October 21, 2012 Share Posted October 21, 2012 Has anyone fitted a Disco1 (facelift) dash to a RR Classic? If so, I would like to hear about the major issues you encountered in this process. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted October 21, 2012 Share Posted October 21, 2012 It shouldn't be too difficult. im guessing you mean like this http://www.gumtree.com/p/cars-vans-motorbikes/classic-range-rover-vogue-lse-soft-dash-brooklands-bodykit-lpg-1994/110979196 Quote Link to comment Share on other sites More sharing options...
jagwit Posted October 21, 2012 Author Share Posted October 21, 2012 Yep, similar to that but pulled out a Disco1. That Rangie dash is the so-called "soft-dash" that only the very last ones came with. Quote Link to comment Share on other sites More sharing options...
task Posted October 22, 2012 Share Posted October 22, 2012 I saw one for sale on leboncoin, a French site a bit like Gumtree, that had a disco 300 day grafted in. Was a 92 2 door, looked like an interesting conversion. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 29, 2012 Share Posted October 29, 2012 IIRC the bulkheads have some significant differences that make it challenging to do, but a grown up will be along shortly to advise if this sacrilege is possible or not Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 29, 2012 Share Posted October 29, 2012 RRC Hard dash is the only way IMHO. Though I do prefer the 89-> one though, probably just due to familiarity Quote Link to comment Share on other sites More sharing options...
q-rover Posted October 30, 2012 Share Posted October 30, 2012 I know someone that did it. Not straight forward, but doable. I'll try and dig up some information. Quote Link to comment Share on other sites More sharing options...
elbekko Posted October 30, 2012 Share Posted October 30, 2012 Should be fairly straightforward to do in a softdash, but then I'd just keep the softdash... Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted November 8, 2012 Share Posted November 8, 2012 I bought a soft-dash dashboard when I had my classic, with the intention of fitting this, which I'd guess would be a pretty similar operation (the soft-dash was fundamentally the same as a 300Tdi disco dash, just with better surface materials and slightly different fittings). As far as I'm aware the disco bulkhead didn't change between 200Tdi and 300Tdi - but I'm not at all certain about this? I never actually got round to fitting it, but there are difference in the brackets on the bulkhead, were cooling and air-con pipes are routed through the bulkhead and major difference in the wiring loom (you can't just unplug the old connectors and plug the new ones in - they're different and in different locations). I can't recall anything else I worked out. It's doable but a fair bit of work. Why a 200Tdi dash? If I was going to all that effort I'd go for the 300Tdi with a decent heater (or even better a proper rangie soft dash if I could get my hands on one - afraid I sold mine years ago). Then again, I'm not that convinced it's such a big step up from the later hard dashes - looks much more modern, does leak air from the vents all over the place, decent heater, but the ergonomics of the earlier dash are much better... Not sure I could convince myself to do it. Quote Link to comment Share on other sites More sharing options...
