Mr Noisy Posted January 30, 2013 Author Share Posted January 30, 2013 As long as you use sensor-safe silicone you could beef up the sealing on the valley gasket a bit, smear some about the place where water might try to get in etc. Yes this is of course an option, im confident the manifold is ok its just the end seals i worry about! Anyway, as usual this task has been shelved for the moment becuase my gearbox is now buggered. Must be all the extra power Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 30, 2013 Share Posted January 30, 2013 You wouldn't be the first to blow a gearbox just after tuning up with MS, I seem to recall Nige having a similar experience with someone else! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted January 30, 2013 Author Share Posted January 30, 2013 I'm not under the impression it's related BUT the fact that the engine now makes good power has encouraged me to use it in much larger amounts of anger, so maybe it is!!! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 8, 2013 Author Share Posted February 8, 2013 Gearbox fixed, front layshaft bearing had badly pitted! ANYWAY All hail petrol engined Land Rovers!! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 11, 2013 Author Share Posted February 11, 2013 Megasquirt really works! :D Not a single misfire in a very deep pond yesterday at Parkwood! Quote Link to comment Share on other sites More sharing options...
Bingy Posted February 12, 2013 Share Posted February 12, 2013 Nice video Sam So now i know where you got your username from Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 15, 2013 Share Posted February 15, 2013 Sam, Make sure you come see us at Donnington - I have a 'little pressie' for you Nige Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 16, 2013 Author Share Posted February 16, 2013 Sam,Make sure you come see us at Donnington - I have a 'little pressie' for you Nige Ooooo! Quote Link to comment Share on other sites More sharing options...
discomark10 Posted February 16, 2013 Share Posted February 16, 2013 Wow 25 pages filled with this junk v8! I mean who'd want a v8 huh! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 16, 2013 Author Share Posted February 16, 2013 Wow 25 pages filled with this junk v8! I mean who'd want a v8 huh! Bloody ridiculous isn't it mark! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 18, 2013 Author Share Posted February 18, 2013 More banter: Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 17, 2013 Share Posted March 17, 2013 More pics!Here's the alternator warning light wire, usually brown/yellow: Choose a nice straight section to fit the diode, with the grey band TOWARDS THE ALTERNATOR: Add some heatshrink: Then heatshrink over the whole thing and pop back in the loom. Job done Hi Sam, can you explain me , what is it ? because now my engine don't stop when i turn off the key, , what is the solution, the diode on the alternator ?? thanks Quote Link to comment Share on other sites More sharing options...
mikec Posted March 17, 2013 Share Posted March 17, 2013 Hi Sam, can you explain me , what is it ? because now my engine don't stop when i turn off the key, , what is the solution, the diode on the alternator ??thanks As far as I know, the diode just needs fitting to the wire as per SAMs pictures, that will cure the not stopping problem. Quote Link to comment Share on other sites More sharing options...
discomark10 Posted March 17, 2013 Share Posted March 17, 2013 1 thing a diode does is it acts like a 1 way valve, is that the problem, the supply to the alternator to start it, also feeds back from the alternator when its running? Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 17, 2013 Share Posted March 17, 2013 ok thanks , but mine is modified i have one big positive to starter, and one "black" on exiting , this is this one ?? i think Quote Link to comment Share on other sites More sharing options...
mikec Posted March 17, 2013 Share Posted March 17, 2013 ok thanks , but mine is modified i have one big positive to starter,and one "black" on exiting , this is this one ?? i think Probably best showing a picture of what you have, but if there's only two wires to your alternator, a big one and a small one then it should be the small one Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 17, 2013 Share Posted March 17, 2013 i think to, i will try this afternoon Quote Link to comment Share on other sites More sharing options...
lansalot Posted March 18, 2013 Share Posted March 18, 2013 This thread has inspired me to drag my 90 out and megasquirt it. Well, the kit has only been lying there for about 3-4 years.. I'd say it's probably about time. ;-) Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 19, 2013 Author Share Posted March 19, 2013 This thread has inspired me to drag my 90 out and megasquirt it. Well, the kit has only been lying there for about 3-4 years.. I'd say it's probably about time. ;-) Very glad to be of service Quote Link to comment Share on other sites More sharing options...
jonost24 Posted March 19, 2013 Share Posted March 19, 2013 More banter: I see you have the Lucas lighter as well....... Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 19, 2013 Share Posted March 19, 2013 mouarfffffffffffffffffff Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2013 Share Posted March 19, 2013 mouarfffffffffffffffffff Is that good or bad? Should we call an ambulance? Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 19, 2013 Author Share Posted March 19, 2013 Is that good or bad? Should we call an ambulance? Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 20, 2013 Share Posted March 20, 2013 Is that good or bad? Should we call an ambulance? good joke from jonost24 so that's good next time : :rofl: :rofl: smileys are international ...... Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 20, 2013 Share Posted March 20, 2013 If i may be so bold.... Maybe if Sam is finished with tuning etc, this thread should be trimmed and locked as was suggested a while back. Its way too good a thread to be filled with off-topic stuff. Just an idea for the mods as every time i see a new post i think something useful tuning-wise has been added, only to find it hasnt.... Quote Link to comment Share on other sites More sharing options...
