Help to megasquirting my 90 4.6l froggy
ANTOINE
Put your engine on TDC
then post up a picture of the trigger wheel and VR sensor / wheel / tooth gap
as Bowie says sounds timing !
Tghere are "2" TDC, PROPER TDC where both valves on No 1 cylinder are closed and the "Other" TDC which the exhaust stroke andwill see one
valve open letting exhaust gasses out
Rocker cover off time - No 1 cylinder TDC + PICTURES
Nige
Triple check your plug wiring, for it to backfire I would think your timing is WAAAY out.
i will do this again, because i think you have right, but i have already do this 2 time, but .........one more time is better, and with pics for you
ok, so we do agree, my wiring is wrong, I think my mistake is that the shema I have read the colors of cables to put in front of the pin number, but I think that with these jacks, the numbering is reversed
I go back tomorrow night so my rocker cover, my Plenium, and I especially commend phase cables of the coil supply JUMO as your schematic, and I think it will be good,
So if it can serve, well read and reread the new explanation and especially not rely on the numbers taken on impervious
ps : google traduc, but me i don't understandthe last sentence, and you ???????just for information
soon : HIAAAaaaaaaaaaaaaaaaaaaaaa
HHHHHHHHHHHIIIIIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
thanks a lot at all
i have verified my timing on the pulley, and it is 10 without touch anything
I have change the table with Nigel'table timing and this is good
now, do correctly the wiring in the car and for you, explain me how tuning :rofl: :rofl: :rofl:
i will finish my new plenium before, i have start with the genuine
HHHIIIIIIIIIIIIIIIIIIIIIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
<iframe width="560" height="315" src="http://www.youtube.com/embed/tV8QaDrhUzM" frameborder="0" allowfullscreen></iframe>
Well done Antoine :D
Sounds sweet, not bad guess on the MSQ in the ECU, even tickover is not bad !
1 x bit of advice (other than to tiday the wiring "a Bit" :P ) BIN THE K&N - they are very bad !
Find a 300 TDi Defender Airbox and add one of those with a new decent air filter, far far better for long engine life
K&N are to filtering what Britpart are to Quality parts
Nige
i don't understand this 2 up sentences, google traduc too ?????
Nige
and i would like put like this with the air sensor between red hose and filter
I like to remind you that my car is French, so inverted from you,
and i have 2 question
I really need to have one derivation of air with idle adjustment screw? on this model because it has not ny, so what are the stepping motor can manage own idle??
also, I want to vapors in the engine air box? I can do?
this is THOR butterfly, so not idle screw
I prepare now for the derivation of the air stepper motor
  • 2 weeks later...
my plenium, i will do another aix box later ,
alors essai du soir, trouver une plaque d alu de 6 et essayer de refaire une plaque pour le pas a pas,
http://www.servimg.com/image_preview.php?i=1376&u=11282891'>111.jpg
après un peu de finition, il me manque a trouver un truc pour repartir à 90
http://www.servimg.com/image_preview.php?i=1378&u=11282891'>211.jpg
comme j ai pas trouver de truc, je pense aussi a la vis de richesse de ralenti, je me tord le cerveau, et je trouve dans le fond du garage une plaque d alu de 3 cm environ d epaisseur
http://www.servimg.com/image_preview.php?i=1377&u=11282891'>311.jpg
je tente de faire un genre de distributeur, pour le mettre à la place de l injecteur de depart a froid ( plenium de 3.5l )
http://www.servimg.com/image_preview.php?i=1379&u=11282891'>411.jpg
ma vis de ralenti
http://www.servimg.com/image_preview.php?i=1381&u=11282891'>511.jpg
http://www.servimg.com/image_preview.php?i=1380&u=11282891'>610.jpg
l arrivée décalée
http://www.servimg.com/image_preview.php?i=1382&u=11282891'>710.jpg
et une fois en place(à l arrache sur l'autre, me reste à trouver une arrivée, je pense sur le filtre a air...............
http://www.servimg.com/image_preview.php?i=1383&u=11282891'>810.jpg
oui je réfléchie aussi a une came d'accélérateur, c est pas fini , c est pour tracer la fixation de gaine d accel, et me donner une idée du recul
alors aujourd'hui mis en place de tout, déjà pour commencer j en avais marre d'attendre pour la soudure alu, donc j ai essayé ça
http://www.durafix.com/
essai sur une plaque avec un bec butagaz, verdict que dalle, car je n'arrive pas à atteindre les 390°
donc je passe chez un pote qui a un chalumeau, essai sur deux plaques d alu identique
http://www.servimg.com/image_preview.php?i=1385&u=11282891'>1010.jpg
******, je fais comme dans leur vidéo, je prend une clef anglaise et essaie d y casser, ben ******, ca tiens méchant, d ailleurs c est toujours en place sur la plaque d alu de chez mon pote.
du coup, on essaye sur le plenium,
<iframe width="560" height="315" src="http://www.youtube.com/embed/SVsq6UOk0z4" frameborder="0" allowfullscreen></iframe>
http://www.servimg.com/image_preview.php?i=1386&u=11282891'>1111.jpg
ca tiens pareils, mais le moulage du plenium est plein de bulle, et donc ca fait dégueulasse..........mais puta in, cela tiens pareil, donc je camouflerai, mais je voulais vous montrer avant
après vite fait, on a monter ma vis de ralenti
http://www.servimg.com/image_preview.php?i=1387&u=11282891'>1211.jpg
puis, cet aprem, je me suis dit que j étais cons de vouloir modifier tout le temps, j ai donc pensé que cela avait commencer avec une 103sp, et là le flash
je fonce chez mon pote marchand de cyclo,
dit t'aurai pas une pipe d admission de 103 ?
http://www.servimg.com/image_preview.php?i=1384&u=11282891'>910.jpghttp://www.durafix.com/
et voilà, l 'arrivée du pas a pas nickel
bon, j ai fini, enfin, je referai ma prise d'air plus tard, là j ai envie et besoin du 90, donc
comme j ai pas reçu la bonne prise, j ai fait une adaptation
http://www.servimg.com/image_preview.php?i=1394&u=11282891'>img_1818.jpg
truc d acell
http://www.servimg.com/image_preview.php?i=1395&u=11282891'>img_1819.jpg
sonde et prise de ralenti
http://www.servimg.com/image_preview.php?i=1396&u=11282891'>img_1820.jpg
en cours
http://www.servimg.com/image_preview.php?i=1399&u=11282891'>img_1823.jpg
branchement de la prise home made en reprenant les bon ordres suivant la demande du MS et la sortie du potar
http://www.servimg.com/image_preview.php?i=1398&u=11282891'>img_1822.jpg
re essai avec le plenium
http://www.servimg.com/image_preview.php?i=1400&u=11282891'>img_1824.jpg
can i use megalogviewer without register ?
because if i register me on my laptop , and i use an another laptop for tuning, how i must do ? can i use the key register on 2 different laptop ??
so , now with diode, it's ok the engine stop correctly, thankssss
I do not understand, my afr gauge is not working properly, or the needle does not rise, it works either way random, so you could watch the video in the previous post (post 169), to give me advice, thank you
to I have try to record on Megatune,
file _ reccord - and give a name
but i don't found it on mlv ?????
The AFR gauge does not mean much unless you have a wideband O2 sensor. With a normal one it is only showing "rich" or "lean", you should ignore the numbers. Narrow-band sensors work almost like a switch, they show about 1v if you are rich, about 0v if you are lean, and about 0.5v at 14.7:1, everything else is uncalibrated.
You don't need to register the software, however, I threw some money in the direction of the developer as I thought it was worth it.
As for two laptops - you'll have to ask the developer for the 'legal' answer, however from a moral standpoint I can't see the problem with using the same key on two laptops if you're using both. You can't really use both at the same time!
The relevant part from the licence agreement is ....
'The standard retail MegaLogViewer License registration agreement covers one (1) user installing the application on up to 3 computers for their own use.'
also...
'You may install the unregistered version of this software on as many computers as you are using for your own personal use.'
