Looking for a Diesel Tachometer
HoSS
You found the instructions for me, thankyou :-)
Let's hope HoSS has access to the necessary 'reference tachometer'.
Although it doesn't meet the display criteria requested in this case, the Tiny-Tach may be suitable as a reference tachometer, although if that is all that is required, searching for 'optical tachometer' on ebay will produce more cost effective possibilities.
Tiny-Tach Diesel instructions here.
Cheers.
I like the look of the Tiny Tach as a cheaper way to implement a tacho than any other I have found so far. Good find!
Martin
Martin
I'm also impressed with the Tiny-Tach. Is there any feedback on these for Land Rover motors?
Todd.
Tiny-Tach Diesel... good bit of kit, easilly installed and has the handy use of an hour counter that you can set service intervals with.
also definately accurate!
mines got a dodgy earth at the mo i think... I installed it in the dark though haha
Its going a little off topic here, as my original post was regarding a classic look gauge.
And i left something out - it needs to be 60mm or 2 3/8", this is why i was having a problem. The VDOs are 2 1/16 (52mm)
