Terminal Removal Tool
need4speed
Does anyone know if there is a tool available to remove the terminals/wires from defender fuseboard?
The terminals are like the type ive shown.
Ive tried using tiny screwdrivers but no joy. I dont want to break anything. Ive already chewed one. Thankfully it was an unused wire!
You might get away with cutting a thin strip from a food tin can and then bend it to a U shape to get the two pronged idea, make sure you give it a rub with some emery cloth to remove any burrs so it doesn't damage the housing or the terminal......
I bought a "special tool" for removing the pins from ISO plugs on car radios once, it was nothing more that a thin flat piece or metal with a handle on the end, it broke after a while so I went back to using a small flat blade screwdriver. I would just use the smallest screwdriver you have and just be careful not to break the tabs, in my experience the "special tools" aren't that special.
Dave
Check 1st post guys. Ive been using jewellers screwdrivers but it doesnt work for some reason. Ive been persevering but im just going to end up breaking something. I just wondered if there was something specific for those terminals..
I think the Defender FB is different to the Disco one but I had a right load of aggro and did as suggested I made a tool from the top of an easy open bean can as my small screw drivers didn't work either :(
I did scavenge the old FB from the 300Tdi Disco but it seems different still with the 200Tdi one!
