jameshub Posted October 17, 2013 Share Posted October 17, 2013 I've purchased a power steering setup which came off a Disc and i'm wanting to install on my 2.5n/a It seems to be something that is common to do, but I can find no instructions on the internet or pictures, so I was hoping someone could assist who has done this or knows how to do it. A step by step guide would be good, or a link to an article explaining this or some pictures of how it looks installed, so I can try and work it out. Basically any help please and I need to swap it asap Thanks Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 17, 2013 Share Posted October 17, 2013 How much of it do you have? Pump, pipes, box etc,. Might be worth having a trawl through the world of "members vehicles" as it may well be covered in a build thread? Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 17, 2013 Author Share Posted October 17, 2013 How much of it do you have? Pump, pipes, box etc,. Might be worth having a trawl through the world of "members vehicles" as it may well be covered in a build thread? I have everything but can't find anyone who has pics etc or a guide to installing Quote Link to comment Share on other sites More sharing options...
C18RCH Posted October 17, 2013 Share Posted October 17, 2013 I did mine as part of my re-build, only mine also now has a 200tdi from a defender but no PAS. The disco bits more or less just bolted on. The steering box just bolts on and the column fits. The pipe fit nicely on the inside of the chassis rails. And because mine has a 200tdi the mounting braket for the pump was already there. Don't bother trying to change the drop arm for a defender one. They are a nightmare to remove. All I did was get the track rod off the disco too. I fabricated a braket to take the steering damper out of some 10mm (probably a bit overkill) alli plate and some U/pipe bolts. The only difficulty was I had to shim the pump to get the pulleys to align and because the resevoir is at the wrong side on a disco I had to fab a braket to hold it. The only additional thing you will need it to fab a braket to take the pump too. I can't help with the pump bracket but I can take pictures of the rest if you want? Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 17, 2013 Author Share Posted October 17, 2013 I did mine as part of my re-build, only mine also now has a 200tdi from a defender but no PAS. The disco bits more or less just bolted on. The steering box just bolts on and the column fits. The pipe fit nicely on the inside of the chassis rails. And because mine has a 200tdi the mounting braket for the pump was already there. Don't bother trying to change the drop arm for a defender one. They are a nightmare to remove. All I did was get the track rod off the disco too. I fabricated a braket to take the steering damper out of some 10mm (probably a bit overkill) alli plate and some U/pipe bolts. The only difficulty was I had to shim the pump to get the pulleys to align and because the resevoir is at the wrong side on a disco I had to fab a braket to hold it. The only additional thing you will need it to fab a braket to take the pump too. I can't help with the pump bracket but I can take pictures of the rest if you want? if you could send some pictures mate that would be awesome and a great starting point. my email is; hubbitjh@hotmail.co.uk cheers Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 20, 2013 Author Share Posted October 20, 2013 hi the only picture I need is one that shows how the pulley/pump fits to the engine. if you could send asap that would be great thanks Quote Link to comment Share on other sites More sharing options...
101sean Posted October 20, 2013 Share Posted October 20, 2013 Didn't think the Tdi pmp mounting bracket fitted earlier engines, could be wrong though.? Basically the alternator mount unbolts off your engine and you fit the combined PAS and alternator mount in its place, it's that simple if the Tdi one fits. Has your engine got a double crankshaft pulley? If not, you'll need to change if for a universal triple one. Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 21, 2013 Author Share Posted October 21, 2013 Didn't think the Tdi pmp mounting bracket fitted earlier engines, could be wrong though.? Basically the alternator mount unbolts off your engine and you fit the combined PAS and alternator mount in its place, it's that simple if the Tdi one fits. Has your engine got a double crankshaft pulley? If not, you'll need to change if for a universal triple one. I was told when I bought it that it is a straight swap........I really hope so otherwise I'm screwed! - yes I have a double pulley as mine was FFR so had 2 alternators (although I took one out) Thanks for this, I will check Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 21, 2013 Share Posted October 21, 2013 Some information you may find helpful... http://www.landyzone.co.uk/lz/f54/pas-200tdi-fit-2-5-na-164231.html http://www.landyzone.co.uk/lz/f7/fitting-power-steering-ex-mod-90-a-30240.html Also might be worth a flick through the parts catalogue, might show you the original set-up. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted October 21, 2013 Share Posted October 21, 2013 Sorry, I have tried to send the pics, I'll check they're not in my outbox or that I've got the emai address correct. The pump fitting won't help though because the mounting brackets are different I believe. The 200tdi one is part of the casting itself. Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 21, 2013 Author Share Posted October 21, 2013 Thanks for this.....seems like some say its easy and some say its a bit more difficult but I have take some pictures of the pump and pulley which fit together and you can see what I mean Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 21, 2013 Author Share Posted October 21, 2013 Sorry, I have tried to send the pics, I'll check they're not in my outbox or that I've got the emai address correct. The pump fitting won't help though because the mounting brackets are different I believe. The 200tdi one is part of the casting itself. My kit consists of; Pump 4 bolt swan neck arm pipes reservoir crank pulley (which I don't need anyway) another small pulley/ tensioner which fit together with the pump and then both need to be fixed to the casing No one seems to mention this extra small pulley which fits with pump, as this has 3 bolt holes to fix to casing Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 21, 2013 Author Share Posted October 21, 2013 Didn't think the Tdi pmp mounting bracket fitted earlier engines, could be wrong though.? Basically the alternator mount unbolts off your engine and you fit the combined PAS and alternator mount in its place, it's that simple if the Tdi one fits. Has your engine got a double crankshaft pulley? If not, you'll need to change if for a universal triple one. does this picture help....this is the pump and the extra pulley/tensioner which has 3 holes and looking at markings it has been fixed to the engine previously Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 21, 2013 Author Share Posted October 21, 2013 does this picture help....this is the pump and the extra pulley/tensioner which has 3 holes and looking at markings it has been fixed to the engine previously another picture of the 2 parts fixed together Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted October 21, 2013 Share Posted October 21, 2013 Regarding the small pulley, I used to have an additional pulley that tensioned the power steering belt on my 2.25 petrol engine. I believe it was fitted to very early systems. When the bearing went in it due to mud etc from off road driving I removed the pulley and fitted a later mounting plate that allows the pump to rotate and tension the belt. I have since sold the petrol engine that would have had the bracket that bolts to the engine. I see that chap that bought it from time to time and would be happy to ask if he wanted to sell it. I also have my old pump, pipes, reservoir and steering box(3 bolt). They are not fitted to the vehicle but are all connected so if I get some time I may be able to dig the out and take a picture if it would help. Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted October 21, 2013 Share Posted October 21, 2013 Hello, Just found this if it helps with the tensioner. http://forums.lr4x4.com/index.php?showtopic=54003 Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 28, 2013 Author Share Posted October 28, 2013 Some information you may find helpful... http://www.landyzone.co.uk/lz/f54/pas-200tdi-fit-2-5-na-164231.html http://www.landyzone.co.uk/lz/f7/fitting-power-steering-ex-mod-90-a-30240.html Also might be worth a flick through the parts catalogue, might show you the original set-up. where can I get a parts manual from? Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 28, 2013 Author Share Posted October 28, 2013 Regarding the small pulley, I used to have an additional pulley that tensioned the power steering belt on my 2.25 petrol engine. I believe it was fitted to very early systems. When the bearing went in it due to mud etc from off road driving I removed the pulley and fitted a later mounting plate that allows the pump to rotate and tension the belt. I have since sold the petrol engine that would have had the bracket that bolts to the engine. I see that chap that bought it from time to time and would be happy to ask if he wanted to sell it. I also have my old pump, pipes, reservoir and steering box(3 bolt). They are not fitted to the vehicle but are all connected so if I get some time I may be able to dig the out and take a picture if it would help. if you could ask him about bracket that would be great Thanks Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2013 Share Posted October 28, 2013 where can I get a parts manual from? on Retroanaconda's webpages this one is for 110 but covers all the 4 cylinder engines & their associated systems http://www.retroanaconda.com/landrover/2010/02/land-rover-defender-110-parts-book/ Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 29, 2013 Author Share Posted October 29, 2013 on Retroanaconda's webpages this one is for 110 but covers all the 4 cylinder engines & their associated systems http://www.retroanaconda.com/landrover/2010/02/land-rover-defender-110-parts-book/ cheers, looks like I have the right bracket but mine has a pulley on it as well Quote Link to comment Share on other sites More sharing options...
western Posted October 29, 2013 Share Posted October 29, 2013 the additional pulley was used on 2.35litre engines, IIRC you don't need it on a 2.5 engine. see page 106 for a detailed diagram for your engine Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 29, 2013 Author Share Posted October 29, 2013 the additional pulley was used on 2.35litre engines, IIRC you don't need it on a 2.5 engine. see page 106 for a detailed diagram for your engine ok, but then i'm missing the tensioner, as I understood the additional pulley was the tensioner Quote Link to comment Share on other sites More sharing options...
western Posted October 29, 2013 Share Posted October 29, 2013 the plate on front of PAS pump is the tensioner as well as the pump mounting plate, the holes are elongated & there is a 1/2 square hole to fit a breaker bar in to hold the tension while the bolts are tightened. Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 29, 2013 Author Share Posted October 29, 2013 the plate on front of PAS pump is the tensioner as well as the pump mounting plate, the holes are elongated & there is a 1/2 square hole to fit a breaker bar in to hold the tension while the bolts are tightened. this is what I have Quote Link to comment Share on other sites More sharing options...
jameshub Posted October 29, 2013 Author Share Posted October 29, 2013 the plate on front of PAS pump is the tensioner as well as the pump mounting plate, the holes are elongated & there is a 1/2 square hole to fit a breaker bar in to hold the tension while the bolts are tightened. or this picture might be better Quote Link to comment Share on other sites More sharing options...
