AdeParko Posted October 25, 2013 Share Posted October 25, 2013 I've replaced the ball joint on my rear A-frame today, but when tightening the 2x long bolts that hold the fulcrum bracket, I managed to strip the threads from the nuts The haynes manual says that they should be torqued to 176nm, but striped the nuts trying to get to this. Can anyone confirm if this is correct? Its now left me in another situation of not having any other 1/2" UNF nyloc nuts to replace them with. Does anyone know of any shops local to the West Lothian area that might stock them?Many thanks Ade Quote Link to comment Share on other sites More sharing options...
Jaytee Posted October 26, 2013 Share Posted October 26, 2013 If you cannot find a supplier in the auto industry try aircraft suppliers such as LAS in Devon as the majority of light aircraft are American and use UNF and UNC hardware. Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2013 Share Posted October 26, 2013 176Nm is correct torque setting, any good engineering supplier or one of the LR parts suppliers should be able to sort 2 new nuts http://www.brit-car.co.uk/search.php?xSearch=NY608042 item 13 in http://lrcat.com/#32/4/45236 Quote Link to comment Share on other sites More sharing options...
AdeParko Posted October 26, 2013 Author Share Posted October 26, 2013 Thanks for the replies In the diagram linked, it's the nuts as item 19 I've completely stripped the threads out of. Bolts seem ok, but won't know until I try some new nuts I've just come across this on the forum http://forums.lr4x4.com/index.php?showtopic=83824 Same symptoms as me, but the replies then suggested it should be fine to 115nm Thanks Ade Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 26, 2013 Share Posted October 26, 2013 Can you get some M10's to fit instead? I think they are very close in size... Quote Link to comment Share on other sites More sharing options...
JimDay Posted October 26, 2013 Share Posted October 26, 2013 I thought all the bolts on Disco's are metric but I could be wrong Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 26, 2013 Share Posted October 26, 2013 Yup, some are still imperial.... Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 26, 2013 Share Posted October 26, 2013 Mostly the fine threads on the suspension but it is a little bit mix and match under there!! Quote Link to comment Share on other sites More sharing options...
woody01 Posted November 3, 2013 Share Posted November 3, 2013 island 4x4 sell the bolt and nuts. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted November 3, 2013 Share Posted November 3, 2013 If your stuck, I know my dad has some of those bolts with nylocks & he is in fife Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 3, 2013 Share Posted November 3, 2013 I'd be tempted to swap out the bolts too ... http://bit.ly/1gkOucn Quote Link to comment Share on other sites More sharing options...
Boris113 Posted November 4, 2013 Share Posted November 4, 2013 I had the same problem when I tightened my bolts up to 176nm Any local agricultural engineers should have UNF bolts in the desired length. They will probably be cheaper than a landy garage too. Quote Link to comment Share on other sites More sharing options...
