gomotomoto Posted December 9, 2013 Share Posted December 9, 2013 Can anyone point me in the direction of a nice and tidy webasto 2000 air heater install? Going to tackle this project and think it might be helpful to see someone's approach to it first. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 9, 2013 Share Posted December 9, 2013 I fitted a eberspacher d1lc in my tomcat and then my 110 if that's any help I would recommend fitting a separate dip pipe shorter than the engine dip pipe or a separate fuel tank. Mike Quote Link to comment Share on other sites More sharing options...
Team Idris Posted December 9, 2013 Share Posted December 9, 2013 Biggest trouble for me on the eber has always been voltage, so big cables are a must on 12 volt. (both live and earth). Choice on the fresh air intake of; Inside to have more heat, (re-circ) or outside to pull fresh air (drier air) I currently run a lock-gate stove which changes the air via the chimney, so I'll recommend the outside air intake, as long as it's away from your exhaust pipe exit Never seen a step by step install though, so can't help there... Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2013 Share Posted December 9, 2013 eberspacher install in a 110SW. haven't seen similare for a Webasto unit though. http://forums.lr4x4.com/index.php?showtopic=18347 Quote Link to comment Share on other sites More sharing options...
gomotomoto Posted December 10, 2013 Author Share Posted December 10, 2013 thanks guys, that thread above is helpful. I'll let you know how the install goes. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 10, 2013 Share Posted December 10, 2013 I've thought about where to put one in my 90 and not settled on where. The seat box is an obvious choice but that's vulnerable to wading, and anywhere else in the cab seems a bit obstructive. Bit there'd be a host of problems to resolve there. It would be nice if you could you fit one in the standard dash - in the heater box part. So that it worked through the standard vents. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 10, 2013 Share Posted December 10, 2013 The seat box is an obvious choice but that's vulnerable to wading, and anywhere else in the cab seems a bit obstructive. Bit there'd be a host of problems to resolve there. I put mine up on the ceiling. I'm planning to move it into the dash as, as you say, there are numerous issues up there, not least that it never heats your feet and it's a long way away on a LWB! It would be nice if you could you fit one in the standard dash - in the heater box part. So that it worked through the standard vents. I reckon that's doable, either in the dash or blowing into the std heater box. Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 10, 2013 Share Posted December 10, 2013 I have a mikuni my30 in mine fitted in the same place as fridge has his. I keep meaning to put some air ducting on it to duct the air somewhere more useful but still havnt got round to it.... Quote Link to comment Share on other sites More sharing options...
gomotomoto Posted January 9, 2014 Author Share Posted January 9, 2014 Mine's in. Works like a champ. Was a great investment. Truck is toasty warm now. Thanks for all the help from this forum. Quote Link to comment Share on other sites More sharing options...
